Auto-generate Shopify blog related articles with OpenAI text-embedding-3-small
Created by: Geoffroy || jojoq42
Geoffroy
Last update a month ago
🪐 Use case
Automatically surface and insert the three most relevant “Related articles” at the end of every Shopify blog post to boost session depth, SEO, and reader engagement.
⚙️ What this workflow does
  • Pulls all published articles from a selected Shopify Blog using the Admin API.
  • Cleans the HTML content (removes existing .related-articles blocks) and extracts text for embeddings.
  • Generates OpenAI embeddings (text-embedding-3-small) and stores them in n8n Data Tables.
  • Calculates semantic similarity (cosine distance) between articles to identify the top matches.
  • Selects the Top 3 most relevant related posts for each article (configurable).
  • Dynamically builds a <div> HTML section and updates the article on Shopify.
  • Runs on a weekly schedule to keep relations fresh as new content is added.
🧩 Setup
  1. Create 3 Data Tables:
    • articles
    • article_relations
    • article_related_links_snapshot
  2. Add credentials:
    • Shopify Admin API Access Token
    • OpenAI API Key
  3. Set environment variables in the Workflow Configuration node:
    • shopifyBlogId
    • shopifyBlogDomain
    • shopifyStoreName
    • shopApiVersion
    • percent_minimum_similarity (default 70)
  4. (Optional) Keep or modify the Schedule Trigger (default: every week at 20:00).
🛠️ How to adjust this template
  • Modify the similarity threshold or number of related posts displayed.
  • Edit the HTML snippet or CSS classes for the related section.
  • Integrate a second OpenAI model to rewrite link titles or summaries for better UX.
💡 Ideal for
Shopify content teams and SEO strategists who want automated, context-aware internal linking to improve engagement and organic ranking.
