Create AI viral videos using NanoBanana 2 PRO & VEO3.1 and publish via Blotato
Created by: Dr. Firas || drfiras
Dr. Firas
Last update a month ago
💥 Create AI Viral Videos using NanoBanana 2 PRO & VEO3.1 and Publish via Blotato
Workflow Overview
Who is this for?
This template is for content creators, marketers, agencies, and UGC studios who want to turn a simple Telegram message into AI-generated vertical videos, automatically published across multiple social platforms using Blotato.
What problem is this workflow solving? / Use case
Creating short-form video ads usually requires:
  • Designing visuals
  • Writing hooks and captions
  • Generating or editing video
  • Manually uploading to TikTok, Instagram, YouTube, Facebook, LinkedIn, X, etc.
This workflow solves that by automating the full pipeline from image + idea → edited image → AI video → multi-platform post.
What this workflow does
  1. Create Image with NanoBanana 2 PRO
    • User sends a photo + caption idea to a Telegram bot.
    • OpenAI Vision analyzes the reference image.
    • An LLM builds a UGC-style image prompt.
    • NanoBanana 2 PRO generates an enhanced, UGC-friendly image.
  2. Generate Video with VEO3.1
    • An AI Agent structures a detailed Veo prompt (scene, camera, lighting, audio).
    • Prompt is optimized and sent to VEO3.1 reference-to-video.
    • The result is a 9:16, ~8s vertical video downloaded back into n8n.
  3. Publish with Blotato
    • Video is uploaded to Blotato.
    • Posts are created for TikTok, Instagram, YouTube, Facebook, LinkedIn, and X using the AI-generated caption, title, and hashtags.
    • A final “Published” message is sent on Telegram.
  1. Create and configure:
    • Telegram bot (token in Set: Bot Token (Placeholder) node).
    • OpenAI credentials.
    • Fal.ai API key (for NanoBanana 2 PRO + VEO3.1).
    • Blotato account + API credentials and connected social accounts.
  2. Import the template into n8n and update all credential references.
  3. Test by sending a product image + short idea to your Telegram bot.
How to customize this workflow to your needs
  • Edit the UGC image prompt system message to change visual style (more cinematic, minimal, etc.).
  • Adjust the VEO prompt optimizer to tweak duration, mood, or camera movement.
  • Enable/disable specific Blotato platforms depending on where you want to publish.
  • Modify the caption/hashtag generation logic to match your brand tone, language, or niche.
👋 Need help or want to customize this?
📩 Contact: LinkedIn
📺 YouTube: @DRFIRASS
🚀 Workshops: Mes Ateliers n8n
📄 Documentation: Notion Guide
Need help customizing?
Contact me for consulting and support : Linkedin / Youtube / 🚀 Mes Ateliers n8n
