Monitor competitor Meta Ads creatives and send alerts with Google Sheets & Telegram
Last update 22 days ago
Categories
This workflow continuously monitors the Meta Ads Library for new creatives from a specific competitor pages, logs them into Google Sheets, and sends a concise Telegram notification with the number of newly discovered ads. It is built as a safe, idempotent loop that can run on a schedule without creating duplicates in your sheet.
Use Case
Manually checking the Meta Ads Library for competitor creatives is time‑consuming, and it’s easy to lose track of which ads you’ve already seen. This workflow is ideal if you want to:
  • Track competitor creatives over time in a structured Google Sheet.
  • Avoid duplicates by matching ads via their unique id field.
  • Get lightweight notifications in Telegram that tell you how many new ads appeared, without spamming you with full ad lists.
  • Run the process on autopilot (daily, weekly, etc.) with a single schedule.
How it Works
The workflow is organized into three logical blocks:
1. Fetch Ads & Handle Pagination
  • Configuration: The Add parameters Set node stores all key request variables:
    • ad_active_status (e.g. active),
    • search_page_ids (competitor page IDs),
    • ad_reached_countries,
    • access_token.
  • Routing: Page or keywords routes execution into one of two HTTP Request nodes:
    • Facebook Ads API by page — the main branch that queries ads by page ID.
    • Facebook Ads API by keywords — an optional branch for keyword‑based searches.
  • Normalization: Facebook Ads API by ... returns the raw ads_archive response. Check the pagination then:
    • extracts data (array of ad objects) into a dedicated field,
    • reads paging.next into next_url for pagination.
  • Pagination Loop:
    • If checks whether next_url is not empty.
    • Set Next URL assigns next_url to a generic url field.
    • Facebook Ads API pagination requests the next page and feeds it back into Check the pagination.
      This loop continues until there is no next_url, ensuring all pages of the Ads Library response are processed.
2. De‑duplicate Ads & Log to Google Sheets
  • Load Existing IDs:
    • Read existing IDs pulls the existing id column from your Google Sheet (configured to read a specific column/range).
    • Collect ID list converts these into a unique, normalized string array existingIds, which represents all ads you have already logged.
  • Attach State:
    • Attach existing ids (Merge node) combines, for each execution, the freshly fetched Meta response (data) with the historical existingIds array from Sheets.
  • Filter New Creatives:
    • Filter new creatives Code node compares each ad’s id (string) against the existingIds set and builds a new data array containing only ads that are not yet present in the sheet.
    • It also protects against duplicates inside the same batch by tracking seen IDs in a local Set.
  • Write New Ads:
    • Split Out expands the filtered data array into individual items (one item per new ad).
    • Add to sheet then performs an appendOrUpdate into Google Sheets, mapping core fields such as id, ad_creation_time, page_name, ad_creative_bodies, ad_snapshot_url, languages, publisher_platforms, and link fields.
    • The column mapping uses id as the matching column so that existing rows can be updated if needed.
3. Count New Ads & Notify in Telegram
  • Count:
    • In parallel with the write step, Split Out also feeds into Count new ads.
    • This Code node returns a single summary item with newCount = items.length, i.e. the total number of new creatives processed in this run.
  • Guard:
    • Any new ads? checks whether newCount is greater than 0. If not, the workflow ends silently and no message is sent, avoiding noise.
  • Notify:
    • When there are new creatives, Send a text message sends a Telegram message to the configured chatId.
    • The message includes {{$json.newCount}} and a fixed link to the Google Sheet, giving you a quick heads‑up without listing individual ads.
Setup Instructions
To use this template, configure the following components.
1. Credentials
  • Meta Ads / HTTP Header Auth:
    • Configure the Meta Ads HTTP Header credentials used by:
      • Facebook Ads API by page,
      • Facebook Ads API by keywords,
      • Facebook Ads API pagination.
  • Google Sheets:
    • Connect your Google account in:
      • Read existing IDs,
      • Add to sheet.
  • Telegram:
    • Connect your Telegram account credentials in Send a text message.
2. The Add parameters Node
Open the Add parameters Set node and customize:
  • ad_active_status: Which ads to monitor (active, all, etc.).
  • search_page_ids: The numeric ID of the competitor Facebook Page you want to track.
  • ad_reached_countries: Comma‑separated list of country codes (US, US, CA, etc.).
  • access_token: A valid long‑lived access token with permission to query the Ads Library.
3. Google Sheets Configuration
  • Read existing IDs
    • Set documentId and sheetName to your tracking spreadsheet and sheet (e.g. an ads tab).
    • Configure the range to read only the column holding the ad id values.
  • Add to sheet
    • Point documentId and sheetName to the same spreadsheet/sheet.
    • Make sure your sheet has the columns expected by the node (e.g. id, creation time, page, title, description, delivery_start_time, snapshot, languages, platforms, link).
    • Confirm that id is included in matchingColumns so de‑duplication works correctly.
4. Telegram Configuration
  • In Send a text message, set:
    • chatId: Your target Telegram chat or channel ID.
    • text: Customize the message template as needed, but keep {{$json.newCount}} to show the number of new creatives.
5. Schedule
  • Open Schedule Trigger and configure when you want the workflow to run (e.g. every morning).
  • Save and activate the workflow.
Further Ideas & Customization
This workflow is a solid foundation for systematic competitor monitoring. You can extend it to:
  • Track multiple competitors by turning search_page_ids into a list and iterating over it with a loop or separate executions.
  • Enrich the log with performance data by creating a second workflow that reads the sheet, pulls spend/impressions/CTR for each logged ad_id from Meta, and merges the metrics back.
  • Add more notification channels such as Slack or email, or send a weekly summary that aggregates new ads by page, format, or country.
  • Tag or categorize creatives (e.g. “video vs image”, “country”, “language”) directly in the sheet to make later analysis easier.
