Automate Shopify product CSV from images using Gemini, GPT-4o, Google Drive & Sheets
Created by: MANISH KUMAR || manipritraj
MANISH KUMAR
Last update 21 days ago
Shopify AI Product Generator : Image-to-CSV Bulk Upload with Gemini & ChatGPT
Shopify AI Automation
Image-to-Product CSV Bulk Upload Automation
This Shopify AI automation is an advanced n8n-powered workflow that converts raw product images into a Shopify-ready product CSV.
It uses AI image analysis, Google Drive, Google Sheets, and Shopify APIs to fully automate product onboarding — from images to structured ecommerce data.
Built for scalable ecommerce automation, this workflow is especially effective for image-first catalogs such as jewelry, fashion, and accessories.
🚀 Features
  • 🖼️ AI Image Analysis — Analyzes product images one by one for higher accuracy and lower risk
  • 🧠 Automatic Category Detection — Identifies main product category (e.g. Jewelry), easily customizable for any niche
  • ✍️ AI Product Content Generation — Creates product names, descriptions (HTML), tags, and attributes
  • 📄 Google Sheets Orchestration — Structures data and outputs a clean Shopify-compatible CSV
  • 🛍️ Shopify Asset Upload — Uploads images to Shopify and retrieves CDN URLs
🧩 Workflow Preparation
Before running the workflow:
  1. Upload all product images to Google Drive
  2. Name images using the format:
    <SKU><ColorCode>
    Example: 12345GR
  3. Place all images inside a folder named:<Brand Name>
  4. Root folder name : pending
Example :
Google_Drive/pending/Manish Collection/All Images
Each image represents one product variant.
⚙️ How It Works
The workflow follows a 6-step automation pipeline designed for reliability and scalability.
Notes :
You may connect all these step to make it fully automatic or shecdule it according to your suitable time.
🔄 Step-by-Step Process
Step 1: Fetch Images from Google Drive
  • Scans the pending/&lt;brand_name&gt; folder
  • Fetches all images
  • Extracts SKU and color code
  • Stores references in Google Sheets
Step 2: AI Image Analysis (One-by-One)
  • Images are analyzed individually
  • Slower than batch processing, but far more reliable
  • Reduces hallucinations and incorrect attributes
Ideal for production-grade Shopify automation.
Step 3: Main Category Identification
  • AI determines the primary product category (example: Jewelry)
  • Prompts can be modified for any ecommerce niche
Step 4: Conditional Product Content Generation
Based on category:
  • Product titles are generated
  • Descriptions are written in Shopify-ready HTML
  • Tags and attributes are created
This replaces repetitive work typically handled via Shopify Flow or manual data entry.
Step 5: Shopify Image Upload
  • Images are uploaded to Shopify assets
  • Shopify returns CDN URLs
  • URLs are mapped back to product data
Step 6: Shopify CSV Generation
  • All enriched data is compiled into a new Google Sheet
  • Output matches Shopify’s product import CSV format
  • File is ready for bulk upload
🛠️ n8n Nodes Used
  • Trigger Node (Manual / Schedule)
  • Google Drive Node
  • Google Sheets Node
  • AI Agent Node (Image Analysis + Content)
  • Switch Node (Category-based logic)
  • Code Node (Formatting & CSV structure)
  • Shopify Node / HTTP Node
🔐 Credentials Required
Before running the workflow, configure the following credentials in n8n:
  • Shopify Access Token — For asset uploads and API calls
  • AI Provider API Key — For image analysis and content generation
  • Google Drive OAuth — To access product images
  • Google Sheets OAuth — To store and export data
👤 Ideal For
This workflow is ideal for:
  • Shopify store owners handling bulk product uploads
  • Ecommerce teams managing image-heavy catalogs
  • Agencies building scalable Shopify automation systems
  • Anyone exploring how to automate Shopify product onboarding
💬 Extensibility
This workflow is modular and easy to extend. You can add:
  • Multi-language product descriptions
  • Pricing and margin automation
  • Shopify marketing automation triggers
  • Shopify Flow integrations after product import
  • Marketplace exports (Google Shopping, Meta, Amazon)
🔑 Keywords
shopify ai
shopify flow
shopify marketing automation
shopify automation
how to automate shopify
📌 Notes
  • No AI fine-tuning required
  • No fragile prompt chaining
  • Designed for accuracy over speed
  • Safe for production ecommerce workflows
📞 Support
If you’re looking to customize or extend this workflow, feel free to reach out or fork the project.
Happy automating 🚀
