Turn new Shopify products into SEO blogs with Perplexity, Gemini and Sheets
Created by: MANISH KUMAR || manipritraj
MANISH KUMAR
Last update a month ago
Manish Kumar
Shopify Product-to-Blog Automation with Perplexity web search, Gemini AI Agent & Google Sheets
Shopify Blog Automation
(From Shopify product to SEO-optimized blog post — fully automated)
This workflow is an advanced n8n-powered automation that transforms newly
created Shopify products into professionally written, SEO-ready blog posts
using AI.
By combining Shopify Webhooks, Google Sheets, AI research, structured content
generation, and automated HTML formatting
, this workflow removes all manual
work from product-based content marketing.
💡 Key Advantages
This Shopify Product-to-Blog Automation delivers the following benefits:
🛍️ Shopify Product Sync
Automatically captures new product data (title, description, vendor, type,
images) the moment a product is created.
🧠 AI-Powered Research & Writing
Uses AI to perform market analysis, identify customer intent, and generate
structured, high-quality blog content.
📊 Google Sheets Tracking
Maintains a clear audit trail of products, generated blogs, and publishing
status to prevent duplication.
🧩 Structured Content Output
Generates strict JSON-based blog sections (problem, solution, features, usage,
comparison, CTA) for consistency and scalability.
📤 End-to-End Automation
Handles everything — from product detection to blog publishing — with zero
manual writing.
⚙️ How It Works
Step-by-Step Process
  1. Shopify Trigger
    Listens for products/create events in Shopify.
  2. Product Data Extraction
    Normalizes product fields and selects the primary product image.
  3. Google Sheets Storage
    Stores raw product data and sets initial processing status.
  4. AI Market & SEO Research
    Analyzes product intent, audience, use cases, FAQs, and keyword opportunities.
  5. AI Blog Content Generation
    Creates structured, SEO-focused blog content using a LangChain AI agent.
  6. HTML Structuring
    Cleans, escapes, and formats content into Shopify-safe, responsive HTML.
  7. Shopify Blog Publishing
    Automatically posts the article to the Shopify Blog via Admin API.
  8. Status Update & Tracking
    Updates Google Sheets to reflect successful blog publication.
🛠️ Setup Steps
Required Node Configuration
To run this workflow, configure the following nodes:
  • Shopify Trigger – Detect new product creation
  • Set Node – Normalize Shopify product fields
  • Google Sheets Nodes – Store and track workflow state
  • AI Research Node – Market & SEO analysis
  • LangChain / Gemini Agent – Blog content generation
  • Code Node – HTML formatting and safety handling
  • HTTP Request Node – Publish blog post to Shopify
  • Error Handling Logic – Retry and fail-safe routing
🔐 Credentials Required
Before enabling the workflow, configure these credentials:
  • Shopify Admin API Access Token – For blog publishing
  • Google Sheets OAuth – For data tracking
  • Google Gemini API Key – For AI content generation
  • Perplexity API Key – For research and SEO insights
👤 Ideal For
This automation is ideal for:
  • Shopify store owners using content marketing
  • Ecommerce teams managing large product catalogs
  • SEO teams scaling product-driven blog content
  • Agencies offering automated Shopify SEO solutions
💬 Bonus Tip
This workflow is fully modular and extensible. You can easily enhance it to:
  • Auto-link blogs to products
  • Generate multilingual blog posts
  • Schedule delayed publishing
  • Route content by product category
  • Add internal linking or schema markup
All extensions can be implemented within the same n8n workflow.
✅ Result
Every new Shopify product automatically becomes:
  • Research-backed
  • SEO-optimized
  • Professionally structured
  • Automatically published
No manual writing. No copy-paste. Fully automated.
Keywords
  • shopify ai
  • shopify automation
  • shopify marketing automation
  • shopify blog automation
  • shopify content automation
  • ai blog generator shopify
  • shopify seo automation
  • ecommerce automation
  • ai ecommerce automation
  • shopify workflow automation
  • shopify product to blog
  • auto generate shopify blogs
  • shopify ai content
  • how to automate shopify
