Import Faire products to Shopify using BrowserAct, Gemini, and Telegram
Last update 23 days ago
Import products from Faire to Shopify using BrowserAct, Gemini and Telegram
This workflow acts as an automated dropshipping assistant. It allows you to send product links from Faire.com to a Telegram bot, which then scrapes the product data, rewrites it for SEO using AI, and imports it directly into your Shopify store—handling images, pricing, and descriptions automatically.
Target Audience
Dropshippers, e-commerce store owners, and inventory managers sourcing products from Faire.
  1. Receive Link: You send a Faire product URL to your Telegram bot.
  2. Analyze Input: An AI Agent classifies your message to determine if it's a product import request or just a chat.
  3. Scrape Product: BrowserAct executes a background task to scrape the product's title, description, price, and images from the provided URL.
  4. Human Verification (CAPTCHA): If the scraper hits a CAPTCHA, the workflow pauses and alerts you on Telegram. Once you solve it, the workflow resumes automatically.
  5. AI Enhancement: A second AI Agent (using Google Gemini) rewrites the product title and description to be SEO-friendly and sales-oriented, formatting it in HTML.
  6. Sync to Shopify: The workflow creates the product in Shopify, adds the correct variant pricing/SKU, and uploads all scraped images.
How to set up
  1. Configure Credentials: Connect your Telegram, Shopify, BrowserAct, and Google Gemini accounts in n8n.
  2. Prepare BrowserAct: Ensure the Product Importer Bot for Shopify template is saved in your BrowserAct account.
  3. Configure Telegram: Ensure your bot is created via BotFather and the API token is added to the Telegram credentials.
  4. Activate: Turn on the workflow.
  5. Test: Send a Faire product link to your bot to start the import process.
Requirements
  • BrowserAct account with the Product Importer Bot for Shopify template.
  • Shopify account (Access Token with write_products permission).
  • Telegram account (Bot Token).
  • Google Gemini account.
How to customize the workflow
  1. Change Pricing Logic: Add a Set node before the "Add Price" node to increase the scraped price by a percentage (markup) before importing.
  2. Translate Content: Modify the system prompt in the Analyzing Products agent to translate the description into another language during the rewrite.
  3. Add More Fields: Update the Analyzing Products agent to extract additional data like "Material" or "Dimensions" and map them to Shopify Metafields.
Need Help?
Workflow Guidance and Showcase Video
