Score and route leads with Telegram alerts and Box storage
Created by: vinci-king-01 || vinci-king-01
vinci-king-01
Last update a month ago
Lead Scoring Pipeline with Telegram and Box
This workflow ingests incoming lead data from a form submission webhook, enriches each lead with external data sources, applies a custom scoring algorithm, and automatically stores the enriched record in Box while notifying your sales team in Telegram. It is designed to give you a real-time, end-to-end lead-qualification pipeline without writing any glue code.
Pre-conditions/Requirements
Prerequisites
  • n8n instance (self-hosted or n8n.cloud)
  • ScrapeGraphAI community node installed
    (not directly used in this template but required by marketplace listing rules)
  • Telegram Bot created via BotFather
  • Box account (Developer App or User OAuth2)
  • Publicly accessible URL (for the Webhook trigger)
  • Optional: Enrichment API account (e.g., Clearbit, PDL) for richer scoring data
Required Credentials
Credential Scope Purpose
Telegram Bot Token Bot Send scored-lead alerts
Box OAuth2 Credentials App Level Upload enriched lead JSON/CSV
(Optional) Enrichment API Key REST Append firmographic & technographic data
Environment Variables (Recommended)
Variable Example Description
LEAD_SCORE_THRESHOLD 75 Minimum score that triggers a Telegram alert
BOX_FOLDER_ID 123456789 Destination folder for lead files
This workflow listens for new form submissions, enriches each contact with external data, calculates a lead score based on configurable criteria, and routes the lead through one of two branches: high-value leads trigger an instant Telegram alert and are archived to Box, while low-value leads are archived only. Errors are captured by an Error Trigger for post-mortem analysis.
Key Steps:
  • Webhook Trigger: Receives raw form data (name, email, company, etc.).
  • Set node – Normalization: Renames fields and initializes default values.
  • HTTP Request – Enrichment: Calls an external enrichment API to augment data.
  • Merge node: Combines original and enriched data into a single object.
  • Code node – Scoring: Runs JavaScript to calculate a numeric lead score.
  • If node – Qualification Gate: Checks if score ≥ LEAD_SCORE_THRESHOLD.
  • Telegram node: Sends alert message to your sales channel for high-scoring leads.
  • Box node: Uploads the enriched JSON (or CSV) file into a specified folder.
  • Error Trigger: Captures any unhandled errors and notifies ops (optional).
  • Sticky Notes: Explain scoring logic and credential placement (documentation aids).
Set up steps
Setup Time: 15-25 minutes
  1. Create Telegram Bot & Get Token
    • Talk to BotFather → /newbot → copy the provided token.
  2. Create a Box Developer App
    • Enable OAuth2 → add https://api.n8n.cloud/oauth2-credential/callback (or your own) as redirect URI.
  3. Install Required Community Nodes
    • From n8n editor → “Install” → search “ScrapeGraphAI” → install.
  4. Import the Workflow JSON
    • Click “Import” → paste the workflow file → save.
  5. Configure the Webhook URL in Your Form Tool
    • Copy the production URL generated by the Webhook node → add it as form action.
  6. Set Environment Variables
    • In n8n (Settings → Environment) add LEAD_SCORE_THRESHOLD and BOX_FOLDER_ID.
  7. Fill in All Credentials
    • Telegram: paste bot token.
    • Box: complete OAuth2 flow.
    • Enrichment API: paste key in the HTTP Request node headers.
  8. Activate Workflow
    • Toggle “Activate”. Submit a test form to verify Telegram/Box outputs.
Node Descriptions
Core Workflow Nodes:
  • Webhook – Entry point; captures incoming JSON payload from the form.
  • Set (Normalize Fields) – Maps raw keys to standardized ones (firstName, email, etc.).
  • HTTP Request (Enrichment) – Queries external service for firmographic data.
  • Merge (Combine Data) – Merges the two JSON objects (form + enrichment).
  • Code (Scoring) – Calculates lead score using weighted attributes.
  • If (Score Check) – Branches flow based on the score threshold.
  • Telegram – Sends high-score alerts to a specified chat ID.
  • Box – Saves a JSON/CSV file of the enriched lead to cloud storage.
  • Error Trigger – Executes if any preceding node fails.
  • Sticky Notes – Inline documentation for quick reference.
Data Flow:
  1. WebhookSetHTTP RequestMergeCodeIf
  2. If (true)Telegram
  3. If (always)Box
  4. Error (from any node) → Error Trigger
Customization Examples
Change Scoring Logic
// Inside the Code node
const { jobTitle, companySize, technologies } = items[0].json;
let score = 0;
if (jobTitle.match(/(CTO|CEO|Founder)/i)) score += 50;
if (companySize > 500) score += 20;
if (technologies.includes('AWS')) score += 10;
// Bonus: subtract points if free email domain
if (items[0].json.email.endsWith('@gmail.com')) score -= 30;
return [{ json: { ...items[0].json, score } }];
Use a Different Storage Provider (e.g., Google Drive)
// Replace Box node with Google Drive node
  "node": "Google Drive",
  "operation": "upload",
  "fileName": "lead_{{$json.email}}.json",
  "folderId": "1A2B3C..."
Data Output Format
The workflow outputs structured JSON data:
  "firstName": "Ada",
  "lastName": "Lovelace",
  "email": "[email protected]",
  "company": "Analytical Engines Inc.",
  "companySize": 250,
  "jobTitle": "CTO",
  "technologies": ["AWS", "Docker", "Node.js"],
  "score": 82,
  "qualified": true,
  "timestamp": "2024-04-07T12:34:56.000Z"
Troubleshooting
Common Issues
  1. Telegram messages not received – Ensure the bot is added to the group and chat_id/token are correct.
  2. Box upload fails with 403 – Check folder permissions; verify OAuth2 tokens have not expired.
  3. Webhook shows 404 – The workflow is not activated or the URL was copied in “Test” mode instead of “Production”.
Performance Tips
  • Batch multiple form submissions using the “SplitInBatches” node to reduce API-call overhead.
  • Cache enrichment responses (Redis, n8n Memory) to avoid repeated lookups for the same domain.
Pro Tips:
  • Add an n8n “Wait” node between enrichment calls to respect rate limits.
  • Use Static Data to store domain-level enrichment results for even faster runs.
  • Tag Telegram alerts with emojis based on score (🔥 Hot Lead for >90).
This is a community-contributed n8n workflow template provided “as-is.” Always test thoroughly in a non-production environment before deploying to live systems.
