Assess technical documentation compliance with GPT‑4o and send Slack alerts
Last update 19 days ago
This n8n template demonstrates how to use AI to automatically review technical documentation against predefined compliance standards — and alert your team via Slack.
Use cases: Engineering teams maintaining API docs, product teams enforcing terminology standards, or localization teams checking readiness before translation handoff.
  • A document URL or raw text is passed in via manual trigger (or webhook).
  • The document content is fetched and extracted as plain text.
  • An AI model scores the document across 4 compliance dimensions: Structure, Terminology, Localization Readiness, and Completeness.
  • The AI returns a structured JSON report with scores and gap descriptions per dimension.
  • A compliance status is determined: PASS / WARNING / FAIL based on the overall score.
  • A formatted Slack alert is sent to the appropriate channel based on status severity.
  • All results are logged for historical tracking.
How to use
  • Replace the document URL in the Set Document Input node with your own source.
  • Update the AI prompt in the Score Documentation with AI node to match your standards.
  • Add your Slack webhook URLs for each severity channel.
  • Optionally connect to Google Sheets or PostgreSQL for audit logging.
Requirements
  • OpenAI or Anthropic API key for AI scoring
  • Slack incoming webhook URLs
  • Document accessible via URL or passed as text
