Generate monthly AI financial reports with OpenAI and email/Slack distribution
Last update 23 days ago
This n8n workflow automatically fetches monthly financial statements, normalizes the data, performs KPI calculations and trend analysis, detects anomalies, generates AI-powered executive insights and recommendations, creates professional reports, and distributes them to stakeholders while maintaining historical records.
Key Insights
  • Consistent data formats from accounting systems (QuickBooks, Xero, etc.) are critical for reliable normalization and analysis.
  • AI-generated insights are only as good as the input data quality — always validate fetched statements and mappings first.
  • Monthly scheduling ensures timely reporting; consider adding manual triggers for ad-hoc runs during testing.
Workflow Process
  1. Initiate the workflow with the Monthly Schedule Trigger node (runs on the 1st of each month at 8 AM).
  2. Fetch current period financial statements (P&L, balance sheet, cash flow) using the accounting API nodes.
  3. Fetch previous period data for accurate YoY/MoM comparisons.
  4. Merge all statements, normalize formats, validate integrity, and calculate standardized KPIs/metrics using data transformation nodes.
  5. Analyze trends, variances, and detect anomalies/unusual patterns.
  6. Send cleaned financial data to an AI model (OpenAI/Claude) to generate natural language executive summaries, key insights, and actionable management recommendations.
  7. Format and generate professional HTML/PDF reports (with charts/visualizations if configured).
  8. Store the report and metrics in a database for historical tracking, post summary to Slack, and email the full report to management/stakeholders.
Usage Guide
  • Import the workflow into n8n and configure credentials for your accounting system(s), AI provider, database, Slack webhook, and email (SMTP).
  • Map fields correctly in the normalization/validation nodes to match your source data structure.
  • Test end-to-end with sample/historical financial data before enabling the schedule.
  • Execute manually first via the Execute workflow button to verify each step (especially API fetches and AI output quality).
Prerequisites
  • API access to accounting system (QuickBooks, Xero, SAP, or direct database connection)
  • OpenAI or Claude API key for insight generation
  • Database (PostgreSQL, MySQL, etc.) with tables ready for reports and metrics storage
  • SMTP server or email service credentials
  • Slack webhook (optional for notifications)
  • PDF/HTML generation tools (if using external services like WeasyPrint via code node or Make.com-style nodes)
Customization Options
  • Adjust the schedule (e.g., quarterly instead of monthly) in the trigger node.
  • Modify the AI prompt in the LLM node to change the style/tone of summaries or add specific focus areas (e.g., cost control, revenue growth).
  • Extend anomaly detection rules or add more KPIs in the analysis section.
  • Change distribution channels (add Teams, Discord, Google Drive upload, etc.) by modifying or adding nodes after report generation.
  • Add conditional branching for high-priority alerts (e.g., if major anomaly detected → immediate notification).
