Any external system triggers a reminder via webhook with a tenant token — the workflow validates the token, fetches the tenant's channel config and message template from PostgreSQL, renders the message with event variables, and sends it immediately
A schedule trigger runs every minute and queries events approaching their deadline window per tenant — idempotency via a reminders_sent table ensures the same reminder is never sent twice
A built-in n8n form lets you register new tenants with their channel, message template and timing rules — no external backend needed
Every send attempt is logged to the database with status, message sent and error details
Set up steps
Add your PostgreSQL credentials to all Postgres nodes (~2 min)
Add your Telegram credentials to the Send Message node (~2 min)
Create the required tables using the SQL schema provided in the workflow sticky note (~10 min)
Register your first tenant at /form/multi-tenant-register
Send events via POST /webhook/multi-tenant-webhook with x-tenant-token header
