Overview
Watch target companies for C-level and VP hiring signals, then send AI-personalized outreach emails when leadership roles are posted.
This workflow reads a list of target company domains from Google Sheets, checks each one for leadership-level job openings via the PredictLeads Job Openings API, enriches matching companies with additional company data, and uses OpenAI to generate a personalized outreach email referencing the specific leadership hire. The email is sent automatically through Gmail.
- A schedule trigger runs the workflow daily at 8:00 AM.
- The workflow reads target account domains from Google Sheets.
- It loops through each company and fetches job openings from PredictLeads.
- It filters for leadership roles such as CRO, CMO, CTO, VP, Head of, Chief, and Director.
- If leadership roles are found, it enriches the company with PredictLeads company data such as industry, size, and location.
- It builds a structured prompt combining company context and the detected leadership roles.
- It sends the prompt to OpenAI to generate a personalized outreach email.
- It sends the AI-generated email through Gmail with a tailored subject line.
- It loops back to process the next company.
Create a Google Sheet with these columns:
Connect your Gmail account using OAuth2 for sending outreach emails.
Add your OpenAI API key in the Generate Outreach Email HTTP Request node.
Add your PredictLeads API credentials using the X-Api-Key and X-Api-Token headers.
Requirements
- Google Sheets OAuth2 credentials
- Gmail OAuth2 credentials
- OpenAI API account using
gpt-4o-mini
- PredictLeads API account:
https://docs.predictleads.com
Notes
- The leadership role filter uses regex matching for roles such as CRO, CMO, CTO, VP, Vice President, Head of, and Chief. You can customize this as needed.
- The AI prompt instructs OpenAI to write concise emails with a maximum of 150 words, referencing the specific leadership hire.
- PredictLeads Job Openings and Company API docs:
