Create AI-powered LinkedIn posts from Telegram with GPT-4 and images
Created by: Ishan Gandhi || automated-ai-systems
Ishan Gandhi
Last update 12 hours ago
🚀 Description
Turn Telegram into your personal AI-powered LinkedIn content assistant.
This workflow lets you create high-quality LinkedIn posts from a simple chat message, refine them with natural feedback, generate matching AI images, and publish directly to LinkedIn—all without leaving Telegram.
Perfect for creators, founders, and professionals who want to stay consistent on LinkedIn without switching between tools.
⚙️ How it works
1. Start with an idea: Send a topic to your Telegram bot (e.g., “Write about AI in marketing”).
2. Instant LinkedIn draft: AI generates a structured, engaging post with a strong hook, insights, and CTA—ready to publish.
3. Refine with feedback: Ask for changes like “make it shorter” or “more professional,” and the workflow updates your draft instantly.
4. Add an AI-generated image (optional): Describe the visual you want, and the workflow creates a polished, LinkedIn-ready image.
5. Approve before publishing: Review and approve both the post and image to maintain full control.
6. Publish in one step: The workflow posts directly to LinkedIn with or without the image.
7. Clean and reset automatically: Your draft is cleared after publishing, and inactive sessions are cleaned up automatically.
🛠️ Set up steps
Estimated time: 10–15 minutes
  1. Create a Telegram bot and connect it in n8n
  2. Add your OpenAI API key (for content and image generation)
  3. Connect your LinkedIn account via OAuth
  4. Activate the workflow and start chatting with your bot
