Turn your best 5-star reviews into a daily stream of branded social proof content -- fully automated. This workflow pulls the oldest unposted 5-star review from Google Sheets, generates a custom quote card using the hcti.io HTML-to-image API, uploads it via Upload to URL to get a stable public CDN link, and publishes it directly to Instagram with a formatted caption. The source row is updated to prevent duplicate posts and the team is notified on Slack.
What This Workflow Does
Review Dispatch Automation
- Schedule Trigger -- fires daily at 9 AM. Adjust the cron expression for any cadence (twice weekly, every other day, etc.)
- Google Sheets -- Fetch Review -- reads the Reviews sheet filtering for Rating = 5 and Posted = FALSE, sorted by Submitted At ascending for FIFO queue dispatch. Fetches exactly one row per run.
- IF -- Has Valid Review -- exits the workflow cleanly on the false branch if no unposted reviews remain. No errors, no failed executions.
Dynamic Quote Card Generation
- Code -- Prepare Fields -- cleans the raw sheet row: truncates review text to card-safe length, formats the star rating as a count, builds the full Instagram caption with attribution line and hashtag block (max 2200 characters).
- Set -- Assemble HTML Card -- constructs a 1080x1080px HTML/CSS quote card template using n8n expressions that reference prepared text fields and env var brand colors. HTML is built in a Set node rather than a Code node to avoid Web Application Firewall false positives on template submission.
- HTTP -- hcti.io -- sends the HTML string to the hcti.io API (HTML/CSS to Image) which renders it as a PNG and returns an image URL. Free tier covers 100 renders per month.
CDN Bridge via Upload to URL
- Upload to URL -- mandatory step. Instagram Graph API requires a direct public HTTPS image URL and rejects binary payloads and base64 strings. This node downloads the rendered PNG from hcti.io and re-uploads it to a CDN, returning a stable public URL Instagram can access.
- Code -- Merge Fields -- combines the CDN URL from Upload to URL with the caption and review metadata from the earlier Code node using cross-node reference.
Instagram Two-Step Publish Flow
- HTTP -- IG Create Media Container -- Step 1 of Instagram publishing. POSTs the CDN image URL and caption to /v19.0/{ig_user_id}/media. Returns a container_id that Instagram uses to stage and validate the image.
- Wait 6s -- processing buffer to ensure Instagram completes async validation before the publish call.
- HTTP -- IG Publish Container -- Step 2. Calls /media_publish with the container_id. Returns the live Instagram Post ID confirming the post is on the feed.
Logging and Notification
- Google Sheets -- Mark as Posted -- updates the source row: sets Posted = TRUE and writes back the Post ID and timestamp. Prevents the same review from being picked up on the next scheduled run.
- Slack -- Notify Team -- sends reviewer name, a 100-character review snippet, the Post ID, and the CDN card URL so the team can verify what went live.
Key Features
- Queue-based dispatch -- reviews post in submission order (FIFO). Oldest unposted 5-star review goes first on every run, keeping the feed chronologically authentic.
- WAF-safe card assembly -- the HTML quote card is built in a Set node using n8n expressions rather than as a raw string in a Code node. This avoids Cloudflare WAF false positives during template submission.
- Mandatory CDN bridge -- Upload to URL is a required step, not optional. Instagram's API will reject any image that is not a direct public HTTPS URL, including hcti.io's own image URLs in some configurations.
- Duplicate-safe -- the Google Sheets update node writes Posted = TRUE immediately after publish. The same review can never be re-queued.
- Source-agnostic -- works with Google Reviews, Trustpilot, Capterra, or any form tool (Typeform, Tally, Jotform) that appends rows to a Google Sheet.
- Fully customizable card design -- background color, text color, and accent color are all controlled by environment variables. No code changes needed to rebrand.
What You Will Need
Credentials
- Google Sheets OAuth2 -- connected to your Reviews spreadsheet
- hcti.io Basic Auth -- user ID and API key from hcti.io (free tier available at hcti.io)
- Upload to URL -- credentials configured in n8n
- Instagram Graph API -- Business or Creator account access token
- Slack OAuth2 -- for team notifications
Google Sheets Columns Required
Reviewer Name -- Review Text -- Rating -- Source -- Posted -- Submitted At -- Instagram Post ID -- Posted At -- Card Image URL
Perfect For
- SaaS companies -- automate a daily customer love post from your existing review pipeline
- E-commerce brands -- convert 5-star product reviews into social proof content on a consistent schedule
- Hospitality and restaurants -- publish verified guest reviews from Google or Tripadvisor automatically
- Agencies -- run one instance per client by swapping env vars, with a separate Google Sheet per brand
- Retail and service brands -- keep Instagram active with authentic customer voices without any manual effort
