Scan incoming Gmail attachments for threats with VirusTotal and GPT-4o-mini
Who's it for
Small teams, solo operators, and security-conscious individuals who receive email attachments from external senders. Useful for freelancers, agencies, HR teams, and anyone handling CVs, invoices, or documents from unknown sources.
Every minute, the workflow polls Gmail for new unread emails with attachments. For each attachment, it calculates the SHA256 hash and queries VirusTotal for known-malware matches. In parallel, an AI model analyzes the email subject and body for phishing patterns. A rule-based scorer combines both signals into three threat levels: Danger (VirusTotal malicious count >= 3 OR AI detects phishing) triggers a Gmail quarantine label plus a Slack alert. Suspicious (partial hits) logs to a human review queue in Google Sheets. Safe saves the attachment to Google Drive. AI is used only for text classification — the final quarantine decision is always rule-based.
Set up steps
  1. Get a free VirusTotal API key at virustotal.com
  2. Create a Google Sheet named suspicious_queue with columns: timestamp, email_from, email_subject, attachment, malicious_count, ai_verdict
  3. Create a Gmail label called QUARANTINE and a Google Drive folder for safe attachments
  4. Open Set Configuration and fill in the Sheet ID, Drive folder ID, Slack channel, and label name
  5. Connect Gmail, Sheets, Drive, Slack, OpenAI, and VirusTotal (Header Auth with x-apikey) credentials
  6. Activate the workflow
How to customize
Adjust thresholds in the Code node, swap Slack for Discord or Teams, or add SPF and DKIM header checks before scanning.
