Draft AI-powered Help Scout replies with HubSpot and SMS customer 360 context
Description
Categories
Customer Support Automation, AI Agents, CRM Integration, SaaS Operations
Build an AI-Driven Cross-Platform Support Context Engine with n8n
This workflow creates an AI-powered middleware layer that unifies customer context across Help Scout, HubSpot, and SMS platforms.
When a new support ticket or reply is received, it fetches the customer's CRM deal stage, onboarding status, and recent text messages. It then generates an AI response, runs it through a secondary QA audit for brand safety, and routes it as a human-reviewed draft in Help Scout.
The result is a highly contextual, zero-blind-spot support system that protects brand voice without sacrificing efficiency.
Benefits
100% Contextual Replies
Agents (and AI) see the full customer journey across all three platforms before responding.
Built-in Brand Protection
Dual-LLM QA gate prevents off-brand, hallucinated, or inappropriate auto-responses.
Human-in-the-Loop Safety
AI drafts are saved, never auto-sent, keeping humans in complete control of final delivery.
Smart Escalation Routing
High-value accounts or angry customers are instantly routed to senior agents with sentiment tags.
Zero Platform Lock-in
Uses standard webhooks and APIs, easily adaptable to other CRMs or ticketing tools.
How It Works
Help Scout Webhook Listener
  • Triggered via webhook when a new conversation or customer reply is created in Help Scout
  • Filters out noise (e.g., internal notes, tag changes) to save API calls
Cross-Platform Data Fetching
  • Simultaneously pulls CRM data from HubSpot (deal value, stage)
  • Pulls recent message history from SMS platforms (e.g., Sales Messenger)
Shared Context Layer Construction
  • Merges ticket payload with CRM and SMS data
  • Formats into a structured "Customer 360" prompt string
AI Draft Generation (LLM 1)
  • Uses GPT-4o to draft a highly empathetic, context-aware reply
  • Restricted to using ONLY the provided shared context to prevent hallucinations
AI QA & Sentiment Audit (LLM 2)
  • Uses a lightweight model (GPT-4o-mini) to evaluate the draft for brand safety
  • Extracts a strict JSON sentiment score (positive/neutral/negative/angry)
Smart Routing & Action
  • If angry/negative → Escalates to a human agent and tags the ticket
  • If high-value but approved → Saves as a draft for an Account Manager
  • Otherwise → Saves as a standard draft for fast agent review
Required Setup
Help Scout
  • API credentials (OAuth2 or App ID/Secret)
  • Webhooks configured in Help Scout (subscribed to convo.created)
  • Permissions to create drafts and assign conversations
HubSpot
  • Private App Token
  • Permissions to search contacts and read deal/custom properties
SMS Platform
  • API access (Sales Messenger, Twilio, or similar)
  • Ability to fetch message history by email or contact ID
AI Model
  • OpenAI API key
  • Configured for GPT-4o (Draft) and GPT-4o-mini (QA)
n8n
  • Self-hosted or cloud
  • Environment variables configured for highValueThreshold and humanAgentId
Business Use Cases
B2B SaaS Support Teams
  • Eliminate the "tell me your account email" friction by arming agents with immediate context
Customer Success Managers
  • Proactively handle onboarding stalls or high-value renewals with full history visibility
Founders & COOs
  • Scale support quality across 1M+ users without risking brand reputation via careless AI auto-replies
Agencies & Consultants
  • Deliver high-end "AI-powered unified inbox" architectures to enterprise clients
Difficulty Level
Advanced
Estimated Build Time
60–90 minutes
Monthly Operating Cost
  • Help Scout: Existing plan
  • HubSpot: Existing plan
  • SMS API: Existing plan
  • AI Model: Usage-based (typically very low for QA/Generation)
  • n8n: Self-hosted or cloud
Typical range: $5–$50/month (highly dependent on ticket volume)
Why This Workflow Works
  • Merging API data into a single context string solves the "disconnected tools" problem natively
  • The two-step LLM approach (Draft + QA) makes AI safe for front-line customer communication
  • Help Scout drafts provide the perfect human-in-the-loop UI without custom frontend builds
  • Sentiment-based routing ensures high-churn-risk tickets get immediate human empathy
Possible Extensions
  • Auto-pause HubSpot email sequences when a negative Help Scout ticket is detected
  • Trigger proactive SMS outreach if a HubSpot onboarding status stalls for X days
  • Log all AI drafts and QA scores to a PostgreSQL database for monthly brand-audit reporting
  • Auto-translate drafts based on the contact's locale before saving the Help Scout draft
  • Use Slack to ping the assigned agent with a summary of the generated draft
Details
Nodes used in workflow
  • Webhook
  • Code (Parse Event & Extract Data)
  • HTTP Request (Fetch HubSpot Context)
  • HTTP Request (Fetch SMS History)
  • Merge
  • Code (Build Shared Context Layer)
  • OpenAI (AI Draft Generator)
  • OpenAI (AI QA & Sentiment Check)
  • Code (Parse QA Output)
  • Switch (Sentiment Router)
  • If (High Value + Approved?)
  • HTTP Request (Save Draft)
  • HTTP Request (Escalate to Human)
  • Respond to Webhook
  • Error Trigger
  • Sticky Note
