Smart Gmail cleaner with AI validator & Telegram alerts
Created by: Reyhan || abizareyhan
Reyhan
Last update 21 days ago
Automatically clean up your Gmail inbox by deleting unwanted emails, validated by Gemini AI.
Ideal for anyone tired of manual inbox cleanup, this workflow helps you save time while staying in control, with full transparency via Telegram alerts.
  • Scans Gmail inbox in adjustable 2-week batches
  • Uses Gemini AI to decide if an email should be deleted or skipped
  • Applies a label to skipped emails to avoid rechecking in future runs
  • Deletes unwanted emails and sends a Telegram message with the AI's reasoning
  • Also notifies on skipped emails, with explanation included
Set up steps
  1. Connect your Gmail, Gemini AI, and Telegram accounts
  2. Adjust the AI baseline to control sensitivity (e.g. how strict the filtering should be)
  3. Set your batch range (default: last 2 weeks, adjustable)
  4. Define your Telegram chat/channel for notifications
Note: Thanks to n8n's modular design, you can easily switch Gemini for another AI model (like OpenAI, Claude, etc.) or replace Telegram with Discord, Slack, or even email, no code changes needed, just swap the nodes.
