AI-powered stock analysis assistant with Telegram, Claude & GPT-4O Vision
Created by: Femi Ad || hgray
Femi Ad
Last update 2 days ago
"Ade Technical Analyst" is a dual-workflow AI system combining conversational intelligence with visual chart analysis through Telegram. The system features 11 primary nodes for conversation management and 8 secondary nodes for chart generation and analysis.
Core Components:
Telegram Integration: Message handling with dynamic typing indicators
AI Personality: "Ade" - a financial analyst with 50+ years NYSE/LSE experience using Claude 3.5 Sonnet
Chart Generation: TradingView integration via Chart-IMG API with MACD and volume indicators
Visual Analysis: GPT-4O vision for technical pattern recognition
Memory System: Session-based conversation context retention
Target Users
Individual traders seeking professional-grade analysis without subscription costs
Financial advisors wanting 24/7 AI-powered client support
Investment educators needing interactive learning tools
Fintech companies requiring white-label analysis solutions
Setup Requirements
Critical Security Fix Needed:
Remove hardcoded API key from Chart-IMG node immediately
Store all credentials securely in n8n credential manager
Required APIs:
OpenRouter (Claude 3.5 Sonnet)
OpenAI (GPT-4O vision)
Chart-IMG API
Telegram Bot Token
Technical Prerequisites:
n8n version 1.7+ with Langchain nodes
Webhook configuration for Telegram
Dual-workflow setup with proper ID referencing
Workflow Requirements
Security Compliance:
Never hardcode API keys in workflow JSON files
Use n8n credential manager for all sensitive data
Implement proper session isolation for user data
Include mandatory financial disclaimers
Performance Specifications:
Model temperature: 0.8 for balanced responses
Token limit: 500 for optimized performance
Dark theme charts with professional indicators
Session-based memory management
Need help customizing?
Contact me for consulting and support or add me on LinkedIn
