Track top social media trends with Reddit, Twitter, and GPT-4o to SP/Drive
Created by: plemeo || plemeo
plemeo
Last update a month ago
Who’s it for
Content creators, marketers, journalists, and product teams who need a quick, automated snapshot of what the internet is talking about—served as a ready-to-use spreadsheet every morning.
How it works / What it does
  1. Manual Trigger / Cron starts the flow.
  2. Set Config picks today’s date and a topic keyword (default “Artificial Intelligence”).
  3. API calls gather trend data:
    Reddit API → /r/artificial “hot” posts.
    Twitter (X) Trends via our own plemeo endpoint or any other social API.
    (Add additional sources before the Merge Data node—Instagram, YouTube, TikTok, etc.)
  4. Aggregate Content concatenates raw titles; AI Agent (GPT-4o) analyses them and returns the top 5 trends in JSON.
  5. Prepare Excel formats each trend into rows; Create Excel turns them into an .xlsx file.
  6. Upload the file to SharePoint (swap for Google Drive, Dropbox, S3—just replace the node).
How to set up
  1. Import the template into n8n (cloud or self-hosted).
  2. Create credentials: Reddit OAuth2, OpenAI, and your preferred storage (SharePoint, Drive, etc.).
  3. In Set Config choose your default topic; adjust the cron schedule if required.
  4. If you’re using Google Drive/Dropbox: delete the SharePoint node and add the corresponding upload node instead.
  5. (Optional) Add more APIs—duplicate Merge Data inputs and map their results in Aggregate Content.
  6. Save & activate. A spreadsheet called social-media-trends.xls appears in your target folder each run.
Requirements
  • n8n 1.33 +
  • Reddit app (OAuth2)
  • OpenAI account
  • One storage credential: SharePoint, Google Drive, Dropbox, or any other supported provider
How to customize
  • Change the number of trends: edit the limit in Aggregate Content and the prompt in AI Agent.
  • Want CSV instead of Excel? Swap Create Excel for Spreadsheet File → to File (CSV).
  • Push trends to Slack/Teams: branch after Prepare Excel and add a chat node.
  • Fully serverless? Trigger via webhook instead of manual/cron.
