Auto-create GitHub PRs & JIRA updates from git commit commands (multi-repo)
Created by: Intuz  || intuz
Intuz
Last update a month ago
Categories
This n8n template from Intuz provides a complete and automated solution for scaling your DevOps practices across multiple repositories.
Are you tired of the repetitive dance between git push, creating a pull request in GitHub, updating the corresponding task in JIRA, and then manually notifying your team in Slack, or Notion?
This template puts your entire post-commit workflow on autopilot, creating a seamless and intelligent bridge between your code and your project management.
By embedding specific keywords and a JIRA issue ID into your git commit commands, this workflow automatically creates a Pull Request in the correct GitHub repository and updates the corresponding JIRA ticket. This creates a complete, centralized system that keeps all your projects synchronized, providing a massive efficiency boost for teams managing a diverse portfolio of codebases.
Who This Template Is For?
This template is a must-have for any organization looking to streamline its software development lifecycle (SDLC). It’s perfect for:
  • Development Teams: Eliminate tedious, manual tasks and enforce a consistent workflow, allowing developers to stay focused on coding.
  • DevOps Engineers: A ready-to-deploy solution that integrates key developer tools without weeks of custom scripting.
  • Engineering Managers & Team Leads: Gain real-time visibility into development progress and ensure processes are followed without constant check-ins.
  • Project Managers: Get accurate, automatic updates in JIRA the moment development work is completed, improving project tracking and forecasting.
Step-by-Step Setup Instructions
Follow these steps carefully to configure the workflow for your environment.
1. Connect Your Tools (Credentials)
  • GitHub: Create credentials with repo scope to allow PR creation.
  • JIRA: Create an API token and connect your JIRA Cloud or Server instance.
  • Slack: Connect your Slack workspace using OAuth2.
  • Notion: Connect your Notion integration token.
2. Configure the GitHub Webhook (For Each Repository)
This workflow is triggered by a GitHub webhook. You must add it to every repository you want to automate.
  • First, Save and Activate the n8n workflow to ensure the webhook URL is live.
  • In the n8n workflow, copy the Production URL from the Webhook node.
  • Go to your GitHub repository and navigate to Settings > Webhooks > Add webhook.
  • In the Payload URL field, paste the n8n webhook URL.
  • Change the Content type to application/json.
  • Under "Which events would you like to trigger this webhook?", select "Just the push event."
  • Click "Add webhook." Repeat this for all relevant repositories.
3. Configure the JIRA Nodes (Crucial Step)
Your JIRA project has unique IDs for its statuses. You must update the workflow to match yours.
  • Find the two JIRA nodes named "Update task status after PR" and "Update the task status without PR."
  • In each node, go to the Status ID field.
  • Click the dropdown and select the status that corresponds to "Done" or "Development Done" in your specific JIRA project workflow. The list is fetched directly from your connected JIRA instance.
4. Configure Notification Nodes
Tell the workflow where to send updates.
  • For Slack: Open the two nodes named "Send message in slack..." and select your desired channel from the Channel ID dropdown.
  • For Notion: Open the two nodes named "Append a block in notion..." and paste the URL of the target Notion page or database into the Block ID field.
5. Final Activation
Once all configurations are complete, ensure the workflow is Saved and the toggle switch is set to Active. You are now ready to automate!
Customization Guidance
This template is a powerful foundation. Here’s how you can adapt it to your team's specific needs.
1. Changing the PR Title or Body:
  • Go to the "Request to create PR" (HTTP Request) node.
  • In the JSON Body field, you can edit the title and body expressions. For example, you could add the committer's name ({{$('Webhook').item.json.body.pusher.name }}) or a link back to the JIRA task.
2. Adapting to a Fixed Branching Strategy:
  • If your team always creates pull requests against a single branch (e.g., develop), you can simplify the workflow.
  • In the "Request to create PR" node, change the base value in the JSON body from {{...}} to your static branch name: "base": "develop".
  • You can then remove the base branch logic from the "Commit Message Breakdown" (Code) node.
3. Modifying Notification Messages:
  • The text sent to Slack and Notion is fully customizable.
  • Open any of the Slack or Notion nodes and edit the text fields. You can include any data from previous nodes, such as the PR URL ({{ $('Request to create PR').item.json.body.html_url }}) or the repository name.
4. Adjusting the Commit Regex for Different Conventions:
  • This is an advanced customization. If your team uses a different commit format (e.g., (DEV-123) instead of DEV-123), you can edit the regular expression in the "Commit Message Breakdown" (Code) node. Be sure to test your changes carefully.
5. Adding/Removing Notification Channels:
  • Don't use Notion? Simply delete the two Notion nodes.
  • Want to send an email instead? Add a Gmail or SMTP node in parallel with a Slack node and configure it with the same data.
Connect with us
For Custom Worflow Automation
Click here- Get Started
