Bypass Cloudflare Turnstile for web scraping with 2captcha
Created by: Ludwig || ludwig
Ludwig
Last update a month ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
Bypass Cloudflare Turnstile for Web Scraping with n8n
How It Works
This workflow automatically solves Cloudflare Turnstile CAPTCHAs for legitimate web scraping and automation tasks. It extracts the Turnstile sitekey from target webpages, submits solving requests to 2captcha, and returns bypass tokens that can be used in automated form submissions or data collection workflows.
Set Up Steps
  1. Create a 2captcha Account: Sign up and get your API clientKey for CAPTCHA solving.
  2. Import the Workflow into n8n: Add the workflow to your n8n instance.
  3. Configure Authentication: Set up custom HTTP authentication with your clientKey in the credential settings.
  4. Test the Workflow: Run with the demo URL to verify Turnstile detection and solving works correctly.
  5. Replace the sample destination_url with your target website and start automating!
Setup should take just a few minutes with your API credentials ready.
Getting Started
Once configured, the workflow can extract sitekeys from any Turnstile-protected webpage and return solved tokens for seamless automation. The API documentation provides additional technical details for advanced use cases.
Customizing the Workflow
The workflow targets a demo page for testing. To adapt it, simply update the destination_url variable with your target website. You can also modify the sitekey extraction logic for sites that implement Turnstile differently, or integrate this as a subworkflow into larger scraping operations.
API Reference
Uses the TurnstileTaskProxyless task type with REST-based HTTPS communication. Each solve costs approximately $0.002 USD and typically completes within 30-90 seconds depending on queue load.
