Beginner AI dataset generator using OpenAI + LangChain in n8n
Created by: Robert Breen || rbreen
Robert Breen
Last update 22 days ago
This n8n workflow dynamically generates a realistic sample dataset based on a single topic you provide. It uses OpenAI (via LangChain) and n8n’s built-in nodes to:
  1. Generate structured JSON data for 5 columns with 3–5 values each
  2. Flatten that data into a single text blob
  3. Infer meaningful column names via a second AI call
  4. Pivot, split, merge, and rename columns automatically
  5. Output a clean, labeled dataset ready for export or further processing
⚙️ Prerequisites
  1. OpenAI API Key
  2. LangChain nodes enabled in your n8n instance
🥇 Step 1: Set Up OpenAI Credential
  1. Go to OpenAI API Keys
  2. Create and copy your key
  3. In n8n: Credentials → New → OpenAI API → paste key as “OpenAi account”
🥈 Step 2: Manual Trigger
  • Add Manual Trigger to start the workflow
🥉 Step 3: Set Topic
  • Add a Set node named Set Topic to Search
  • Field: Topic = n8n use cases (or any topic you choose)
✨ Step 4: Generate Structured Data
  • LangChain Agent node Generate Random Data
  • Connect to OpenAI Chat Model1 and Tool: Inject Creativity1
  • System prompt: instruct AI to output 5 columns of realistic values in JSON
🔧 Step 5: Parse AI Output
  • Structured Output Parser to validate JSON
🔄 Step 6: Flatten Data
  • Code node Outpt all Data to One Field
  • Joins all values into a comma-separated string for column naming
🧠 Step 7: Generate Column Names
  • LangChain Agent Generate Column Names
  • Connect to OpenAI Chat Model2
  • Prompt: infer 5 column names from the string
🔢 Step 8: Pivot Names Row
  • Code node Pivot Column Names transforms array into { column1: name1, … }
🪓 Step 9: Split Columns
  • 5 SplitOut nodes to break each array back into rows per column
🔗 Step 10: Merge Rows
  • Merge node Merge Columns together using combineByPosition
🏷️ Step 11: Rename Columns
  • Set node Rename Columns assigns the AI-generated names to each column
🔗 Step 12: Final Output
  • Merge Append Column Names combines data and header row
🏁 Done! You now have a fully AI-driven, labeled dataset generated from a single topic—no external services needed. Easily extend by adding a Google Sheets or HTTP node to export.
📬 Need Help or Want to Customize This?
📧 [email protected]
🔗 LinkedIn
