This n8n workflow finds experts on any topic, scrapes their websites, and pulls out contact emails automatically.
Core services used: SerpAPI (google search) · Apify (website crawler) · OpenAI (GPT-4o email extraction).
🛠️ Step-by-Step Setup & Execution
1️⃣ Run Workflow (Manual Trigger)
Node |
Type |
Purpose |
Run Workflow |
Manual Trigger |
Start the workflow on demand while you test. |
2️⃣ Set Your Topic
Node |
Type |
How to configure |
Set Topic |
Set |
Add a string field Topic – e.g. "n8n" . This keyword drives every subsequent step. |
3️⃣ Search Google (Results 1-10)
Node |
Type |
API Credential |
Search Google (top 10) |
SerpAPI |
Create SerpAPI credential<br>1. Sign up → copy API key → n8n → Credentials → New → SerpAPI → paste.<br>2. Select the credential in this node. |
Key Params |
q |
={{ $json.Topic }} Expert |
location |
Region code (ex 585069efee19ad271e9c9b36 ) |
additionalFields.start |
"10" (Google position 1-10) |
4️⃣ Search Google (Results 11-20)
Node |
Type |
Notes |
Search Google (11-20) |
SerpAPI (same credential) |
Remove start or set to 20+ to fetch next page. |
5️⃣ Extract URL Lists
Node |
Type |
Script Purpose |
Extract Url & Extract Url 2 |
Code |
Loop data.organic_results → output { title, link, displayed_link } for each result. |
6️⃣ Combine Both Result Sets
Node |
Type |
Details |
Append Results |
Merge (combineAll) |
Merges arrays from steps 3 & 4 into a single list for processing. |
7️⃣ Loop Over Every URL
Node |
Type |
Configuration |
Loop Over Items1 |
Split In Batches |
Default batch = 1 (process one page at a time).<br>onError = continueRegularOutput keeps loop alive on failures. |
8️⃣ Scrape Webpage Content (Apify)
Node |
Type |
API Credential |
Scrape URL with apify |
HTTP Request |
Create Apify credential<br>1. Sign up at https://console.apify.com<br>2. Account → API tokens → copy.<br>3. n8n → Credentials → New → HTTP Query Auth → set query param token=YOUR_TOKEN . |
Request Details |
Method |
POST |
URL |
https://api.apify.com/v2/acts/6sigmag~fast-website-content-crawler/run-sync-get-dataset-items |
JSON Body |
json { "startUrls": ["{{ $json.link }}"] } |
9️⃣ Extract Email with OpenAI
Node |
Type |
API Credential |
Extract Email from webpage |
LangChain Agent |
Create OpenAI credential<br>1. Generate key at https://platform.openai.com/account/api-keys<br>2. n8n → Credentials → New → OpenAI API → paste key. |
Prompt (system) |
extract the email address from the text. if there is no email address, output null. |
Output Parser |
Structured Output Parser2 expects → { "email": "address OR null" } |
🔟 Loop Continues & Final Data
💡 Optional Enhancements
Idea How
Save Leads Add a Google Sheets or Airtable node after the loop.
Validate Emails Chain a ZeroBounce / Hunter.io verification API before saving.
Parallel Crawling Increase SplitInBatches size (watch Apify rate limits).
🙋♂️ Need More Help?
Robert Breen – Automation Consultant & n8n Expert
📧 [email protected]
🔗 https://www.linkedin.com/in/robert-breen-29429625/
🌐 https://ynteractive.com
