Generate smart Calendly notifications for Outlook and Slack using GPT-4
Created by: Robert Breen || rbreen
Robert Breen
Last update a day ago
This n8n automation notifies you whenever someone books a meeting with you via Calendly. It sends a customized email via Outlook and a Slack message using details from the event.
📌 What This Workflow Does
  1. Listens for new Calendly meeting bookings (invitee.created).
  2. Extracts key details (name, email, reason for meeting, start time).
  3. Uses an AI agent to generate both:
    • A HTML email sent to you via Outlook.
    • A Slack message sent to your chosen channel.
⚙️ Step-by-Step Setup Instructions
1. 🔗 Calendly API Setup
  • In n8n: Go to Credentials → Add Credential → Calendly API.
  • Connect your account with the personal access token.
  • In the Calendly Trigger node, set event to invitee.created.
2. 📧 Microsoft Outlook Credential
  • Add Microsoft Outlook credentials via OAuth2 in n8n → Credentials.
  • Select it in the "Send a message" node.
3. 💬 Slack Setup
  • Add Slack OAuth2 credentials.
  • Select your Slack workspace and choose the channel (e.g., #leads).
4. 🧠 Configure the AI Agent (OpenAI)
  • Provide your OpenAI API key under Credentials → OpenAI API.
  • The AI Agent node is pre-configured to:
    • Format a custom Slack message
    • Format a custom Outlook HTML email
5. 🛠 Node Details
  • Calendly Event (Trigger): Listens for new bookings
  • Edit Fields: Extracts values like name, email, start time, and form answers
  • Email Generator (AI Agent): Creates formatted email + Slack message
  • Send a message (Outlook): Sends the formatted email to your inbox
  • Slack Message: Sends the AI-generated Slack alert
🧪 Example Output
Slack Message:
