Send daily AI-generated quotes & images to Telegram with GPT-4o and Flux-pro
Last update 22 days ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
🌅 Daily AI Inspiration (n8n + AI/ML API + Telegram)
This n8n workflow sends a short, original AI‑generated quote and a matching cinematic image to your Telegram chat every morning. It auto‑captures your chat ID from the first message you send to the bot, then runs on a daily schedule.
🚀 Key Features
  • Zero‑Friction Delivery — Just send any message once; the chat ID is saved for daily drops.
  • AI Quote Writer — GPT‑4o crafts concise, uplifting quotes (no author, no quotes).
  • Cinematic Visuals — flux-pro turns each quote into a mood‑rich illustration.
  • Hands‑Off Scheduling — Runs at a set time every day via Schedule Trigger.
  • Telegram Ready — Sends the image + caption directly to your chat.
🛠 Setup Guide
  1. Create AI/ML API Credentials
  • Get your API key in AI/ML API.
  • In n8n → Credentials, add AI/ML API (Bearer token, Base URL https://api.aimlapi.com/v1).
  1. Create Telegram Credentials
  • In Telegram, open @BotFather/newbot → save the bot token.
  • In n8n → Credentials → Telegram API, paste the token.
  1. Capture Chat ID
  • Start the workflow, message your bot once (Telegram Trigger will store the chat ID automatically).
  1. Schedule & Test
  • Set your preferred time in Schedule Trigger (e.g., 07:30).
  • Execute once to confirm delivery, then enable the workflow.
💡 How It Works
  1. Trigger — Runs daily via Schedule Trigger (or manually after first chat message to capture chat ID).
  2. Quote Generation — AI/ML API (GPT‑4o) produces a short, original, uplifting line.
  3. Image Creation — AI/ML API (flux-pro) renders a cinematic image inspired by the quote.
  4. Telegram Delivery — Sends the image to your chat with the quote as the caption (🌅 prefix).
Optional: tweak image size (1024×1024 by default), add logging (Google Sheets), or extend with moderation, model switching, or multi‑chat routing.
