Automated cover letter generator with Indeed job scraping and GPT-4o-mini
Created by: Robert Breen || rbreen
Robert Breen
Last update 2 months ago
Categories
This workflow automates the process of writing tailored cover letters for job applications. It:
  1. Uses Apify’s Indeed Scraper to pull live job postings based on your chosen search term.
  2. Sends the job description along with your resume into OpenAI, which writes an optimized cover letter — one paragraph plus bullet points — only using details from your resume.
Perfect for quickly generating professional, customized cover letters for each role you want to apply to.
⚙️ Setup Instructions
1️⃣ Set Up OpenAI Connection
  1. Go to OpenAI Platform
  2. Navigate to OpenAI Billing
  3. Add funds to your billing account
  4. Copy your API key into the OpenAI credentials in n8n
2️⃣ Set Up Apify Connection
  1. Go to Apify Console and sign up/login
  2. Get your API token here: Apify API Keys
  3. Set up this scraper in your Apify account:
  4. In n8n, create a HTTP Query Auth credential
    • Query Key: token
    • Value: YOUR_APIFY_API_KEY
  5. Attach this credential to the HTTP Request node (Search Indeed)
📬 Contact Information
Need help customizing this workflow or building similar automations?
📧 [email protected]
🔗 Robert Breen
🌐 ynteractive.com
