Automate Morning Brew–style Reddit Digests and Publish to DEV using AI
Created by: Angel Menendez || djangelic
Angel Menendez
Last update a month ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
Who’s it for
Community managers, content marketers, and builders who want a daily, skimmable update from a subreddit—automatically summarized, formatted, and cross-posted to DEV Community.
Here is a Link to video hackathon detailing this build.
What it does
  • Collects fresh posts from a subreddit (seeded via RSS).
  • Uses the Bright Data node to batch-scrape each post for richer fields (upvotes, comment count, comments).
  • Flattens comments/replies with JMESPath and trims payload size.
  • Summarizes into a Morning Brew–style brief (Top Stories, Quick Hits, Community Q&A, Comment Spotlight).
  • Converts to clean Markdown and publishes to DEV with HTTP Request.
  • Optional: emails the same digest via Gmail.
How to set up
  1. Trigger: Start with Manual Trigger; swap to Cron (daily) when ready.
  2. RSS → URLs: Set the subreddit RSS of your choice, just add .rss to the end of the subreddit URL.
  3. Update AI Prompt to fit your needs
Requirements
  • DEV Community API key.
  • Bright Data account + the Bright Data api key Found Here.
  • Optional: LLM provider credentials (OpenAI, Gemini).
How to customize
  • Swap DEV publishing for email/Slack; or post both.
  • Add more subreddits and dedupe by URL.
Best practices
  • No hardcoded API keys—use credentials.
  • Pin long-running outputs while building to save credits.
  • Only collect publicly available data with Bright Data.
