Auto-generate & post LinkedIn carousels with Gemini AI and Post Nitro
Last update a month ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
Try It Out!
Automatically generate Linkedin Carousal and Upload to Linkedin
Use case : Linkedin Content Creation, specifically carousal. But could be adjusted for many other creations as well.
  • It will run automatically every 6:00 AM
  • Get latest News from TechRadar
  • Parse it into readable JSON
  • AI will decide, which news resonates with your profile
  • Then give the title and description of that news to generate the final linkedin carousal content.
  • This step is also trigerred by Form trigger
  • After carousal generation, it will give it to Post Nitro to create images on that content.
  • Post Nitro provides the PDF file.
  • We Upload the PDf file to Linkedin and get the file ID, in next step, it will be used.
  • Finally create the Post description and Post it to Linkedin
How to use
  • It will run every 6:00 AM automatically. Just make it Live
  • Submit the form, with correct title and description ( i did not added tests for that so must give that correct 😅 )
Requirements
  • Install Post Nitro community Node
    @postnitro/n8n-nodes-postnitro-ai
  • We need the following API keys to make it work
  1. Google Gemini ( for Gemini 2.5-Flash Usage )
    Docs Google Gemini Key
  2. Post Nitro credentials ( API key + Template id + Brand id )
    Docs Post Nitro
  3. Linkedin API key
    Docs Linkedin API
Need Help?
Message on Linkedin the Linkedin
Happy Automation!
