LinkedIn lead generation: Auto DM system with comment triggers using Unipile & NocoDB
Last update 23 days ago
Short Description
This LinkedIn automation workflow monitors post comments for specific trigger words and automatically sends direct messages with lead magnets to engaged users. The system checks connection status, handles non-connected users with connection requests, and prevents duplicate outreach by tracking all interactions in a database.
Key Features
  • Comment Monitoring: Scans LinkedIn post comments for customizable trigger words
  • Connection Status Check: Determines if users are 1st-degree connections
  • Automated DMs: Sends personalized messages with lead magnet links to connected users
  • Connection Requests: Asks non-connected users to connect via comment replies
  • Duplicate Prevention: Tracks interactions in NocoDB to avoid repeat messages
  • Message Rotation: Uses different comment reply variations for authenticity
  • Batch Processing: Handles multiple comments with built-in delays
Who This Workflow Is For
  • Content creators looking to convert post engagement into leads
  • Coaches and consultants sharing valuable LinkedIn content
  • Anyone wanting to automate lead capture from LinkedIn posts
How It Works
  1. Setup: Configure post ID, trigger word, and lead magnet link via form
  2. Comment Extraction: Retrieves all comments from the specified post using Unipile
  3. Trigger Detection: Filters comments containing the specified trigger word
  4. Connection Check: Determines if commenters are 1st-degree connections
  5. Smart Routing: Connected users receive DMs, others get connection requests
  6. Database Logging: Records all interactions to prevent duplicates
Setup Requirements
Required Credentials
  • Unipile API Key: For LinkedIn API access
  • NocoDB API Token: For database tracking
Database Structure
**Table: leads
  • linkedin_id: LinkedIn user ID
  • name: User's full name
  • headline: LinkedIn headline
  • url: Profile URL
  • date: Interaction date
  • posts_id: Post reference
  • connection_status: Network distance
  • dm_status: Interaction type (sent/connection request)
Customization Options
  • Message Templates: Modify DM and connection request messages
  • Trigger Words: Change the words that activate the workflow
  • Timing: Adjust delays between messages (8-12 seconds default)
  • Reply Variations: Add more comment reply options for authenticity
Installation Instructions
  1. Import the workflow into your n8n instance
  2. Set up NocoDB database with required table structure
  3. Configure Unipile and NocoDB credentials
  4. Set environment variables for Unipile root URL and LinkedIn account ID
  5. Test with a sample post before full use
