Create high quality UGC images with Nano Banana (Cheaper & Faster)
Created by: Nasser || nasser
Nasser
Last update 13 days ago
Who’s it for?
  • Content Creators
  • E-commerce Stores
  • Marketing Team
Description: Generate unique UGC images for your products. Simply upload a product image into a Google Drive folder, and the workflow will instantly generate 50 unique, high-quality AI UGC images using Nano Banana via Fal.ai.
All results are automatically saved back into the same folder, ready to use across social media, e-commerce stores, and marketing campaigns.
How it works?
📺 YouTube Video Tutorial:
Watch on YouTube
1 - Trigger: Upload a new Product Image (with white background) to a Folder in your Google Drive
2 - Generate 50 different Image Prompts for your Product
3 - Loop over each Prompt Generated
4 - Generate UGC Content thanks to Fal.ai (Nano Banana)
5 - Upload UGC Content on the initial Google Drive Folder
==Cost: 0.039$ / image==
How to set up?
1. Accounts & APIs
In the Edit Field "Setup" Node replace all ==[YOUR_API_TOKEN]== with your API Token :
In Credentials on your n8n Dashboard, connect the following accounts using ==Client ID / Secret==:
2. Requirements
  • Base Image of your Product preferably have a White Background
  • Your Google Drive Folder and every Files it contains should be publicly available
3. Customizations
  • Change the amount of total UGC Generated: In Generate Prompts → Message → "Your task is to generate 50"
  • Modify the instructions to generate the UGC Prompts: In Generate Prompts → Message
  • Change the amount of Base Image: In Generate Image → Body Parameters → JSON → image_urls
  • Change the amount of UGC Generated per prompt: In Generate Image → Body Parameters → JSON → num_images
  • Modify the Folder where UGC Generated are stored: In Upload File → Parent Folder
