🐟 Smart fish feeder: weather-based feeding system with BMKG & Telegram alerts
Last update 22 days ago
🌦️ Intelligent Aquaculture Automation for Indonesia
Transform your fish farming operation with this cutting-edge n8n workflow that combines Indonesia's official BMKG weather data with IoT-powered feeding automation. This system intelligently reduces feed by 20% when rain probability exceeds 60%, preventing overfeeding during adverse weather conditions that could compromise water quality and fish health.
πŸš€ Key Features
🌦️ Real-time BMKG Integration: Fetches official Indonesian weather forecasts every 12 hours using BMKG's public API with precise ADM4 regional targeting
πŸ€– Smart Decision Engine: Advanced JavaScript algorithms analyze 6-hour and 12-hour rain probabilities to make optimal feeding decisions automatically
πŸ“± ESP8266 IoT Control: Seamlessly sends HTTP webhook commands to your ESP8266/ESP32-based fish feeder hardware with JSON payloads
πŸ’¬ Rich Telegram Notifications: Comprehensive reports including weather analysis, feeding decisions, hardware status, and next feeding schedule
⏰ Precision Scheduling: Automated execution at 05:30 and 16:30 WIB (Indonesian Western Time) with cron-based triggers
πŸ“Š Activity Logging: Complete audit trail with timestamps, weather data, and feeding decisions for operational monitoring
πŸ› οΈ Technical Architecture
Core Node Components:
  • Schedule Trigger: Automated twice-daily execution
  • HTTP Request: BMKG API integration with timeout handling
  • Code (JavaScript): Weather parsing and feeding ratio calculations
  • IF Condition: Intelligent branching based on configurable rain thresholds
  • Telegram: Formatted notifications with markdown support
  • Set Variables: Secure credential management with placeholder tokens
πŸ“‹ Prerequisites
βœ… n8n Instance: Self-hosted or cloud deployment
βœ… Telegram Bot: Create via @BotFather for notifications
βœ… ESP8266/ESP32: Hardware with servo motor for automated feeding
βœ… Arduino Skills: Basic programming knowledge for hardware setup
βœ… Indonesian Location: Uses BMKG API with ADM4 regional codes
βš™οΈ Configuration Requirements
πŸ“ Location Settings: Update latitude, longitude, and BMKG ADM4 code in the Config node
πŸ€– Telegram Bot: Configure bot token and chat ID in credentials
πŸ”— ESP8266 Webhook: Set your device's IP address for hardware communication
πŸ“Š Feeding Parameters: Customize rain threshold (default: 60%) and feed reduction (default: -20%)
🎯 Perfect For
🏭 Commercial Aquaculture: Large-scale fish farming operations requiring weather-aware feeding
🏠 Hobbyist Enthusiasts: Home aquarium and pond automation projects
🌱 Smart Agriculture: Integration with comprehensive farm management ecosystems
πŸ”§ IoT Learning: Educational platform for weather-based automation development
🌍 Environmental Research: Combining meteorological data with livestock care protocols
πŸ“Š Rich Output Examples
The workflow generates detailed Telegram reports featuring:
  • Current Weather Analysis: 6-hour and 12-hour rain probability breakdowns
  • Feeding Decision Logic: Clear rationale for feed adjustments with percentages
  • Hardware Confirmation: ESP8266 response status and command execution verification
  • Schedule Preview: Next automated feeding time with countdown
  • Historical Logs: Comprehensive activity tracking for pattern analysis
πŸ”§ Hardware Integration Guide
Designed for ESP8266-based feeders accepting HTTP POST commands. The workflow transmits structured JSON containing:
  "command": "FEED_REDUCE_20",
  "feed_ratio": -20,
  "rain_prob": 75,
  "timestamp": "2024-09-18T10:30:00Z",
  "location": "Main Pond"
🌍 Regional Adaptation
Indonesia-Optimized: Built specifically for BMKG's official weather API with ADM4 regional precision
Global Compatibility: Easily adaptable for international weather services by modifying HTTP requests and parsing logic
Scalable Architecture: Supports multiple pond locations with separate ADM4 configurations
πŸ”’ Security & Credentials
  • All API keys use {{PLACEHOLDER}} format for secure credential management
  • No hardcoded sensitive information in workflow nodes
  • Telegram bot tokens managed through n8n's credential system
  • ESP8266 webhooks support local network security
πŸ“ˆ Performance Benefits
  • 20% Feed Optimization: Automatic reduction during high rain probability periods
  • Water Quality Protection: Prevents overfeeding that degrades aquatic environment
  • Cost Efficiency: Reduces feed waste while maintaining fish health
  • 24/7 Monitoring: Continuous weather analysis without manual intervention
  • Scalable Operations: Supports multiple feeding locations from single workflow
