Convert Telegram channel posts to WooCommerce products automatically
Created by: Shohani || shohani
Shohani
Last update a month ago
Auto-publish Telegram channel posts to WooCommerce store
This n8n template automatically converts Telegram channel posts into WooCommerce products, perfect for businesses that share products on Telegram and want to sync them with their online shop.
Who's it for
E-commerce businesses, dropshippers, and retailers who:
  • Use Telegram channels to showcase products
  • Want to automatically sync products to their WooCommerce store
  • Need to reduce manual data entry between platforms
  • Handle multiple product images and want them properly organized
The workflow monitors your Telegram channel for new posts and automatically creates corresponding WooCommerce products:
  1. Telegram Trigger detects new channel posts with photos and captions
  2. Text Processing extracts product details from the post:
    • First line becomes the product title
    • First hashtag determines the product category
    • Price is extracted using regex patterns
    • Channel signature is removed from description
  3. Image Handling downloads and uploads images to WordPress media library
  4. Category Matching fetches WooCommerce categories and matches them with hashtags
  5. Product Creation creates the WooCommerce product with all extracted data
  6. Multi-Image Support handles posts with multiple images by updating the product
How to set up
  1. Telegram Setup:
    • Create a Telegram bot and get the API token
    • Add the bot to your channel as an administrator
    • Configure the Telegram Trigger with your bot credentials
  2. WooCommerce Setup:
    • Enable WooCommerce REST API in your WordPress admin
    • Create API keys with read/write permissions
    • Configure the WooCommerce nodes with your API credentials
  3. WordPress Setup:
    • Configure HTTP Basic Auth for WordPress REST API
    • Update the woocommerce_url in the SetFields node with your domain
  4. Channel Post Format:
    • First line: Product title
    • Include at least one photo
    • Add price in format: 9,500,000 or 9.500.000
    • Use hashtags that match your WooCommerce category names
    • End posts with your signature after the divider character
Requirements
  • Active Telegram bot with channel admin access
  • WooCommerce store with REST API enabled
  • WordPress with media upload permissions
How to customize the workflow
Price Format: Modify the regex patterns in the Code node to match your currency format
Category Mapping: Ensure your Telegram hashtags exactly match your WooCommerce category names
Signature Divider: Change the signature divider character in SetFields node (default: "_")
Image Quality: Adjust the Telegram file download to get different image resolutions
Product Status: Modify the product creation node to set products as draft instead of published
