Parse & evaluate HR candidates with GPT-4.1 and LinkedIn data in CSV/XLSX
Created by: Elay Guez || elay96
Elay Guez
Last update a month ago
Categories
AI-Powered HR Candidate Evaluation Agent with LinkedIn Data Enrichment in CSV/XLSX Format
🎯 Overview
Transform your manual hiring process into an intelligent evaluation system that saves 15-20 minutes per candidate! This workflow automates the entire candidate assessment pipeline - from CSV/XLSX upload to AI-powered scoring with LinkedIn insights.
When you upload a candidate list, this workflow automatically:
  • 📊 Converts your file into a formatted Google Sheet with RTL support
  • 🔍 Researches each candidate's recent LinkedIn posts via Apify
  • 🤖 Evaluates candidates using GPT-4.1 with context-aware scoring (0-100)
  • 💬 Generates professional Hebrew explanations for each score
  • 📈 Auto-sorts by score and applies professional formatting
  • ⚠️ Sends error alerts to keep everything running smoothly
Cost per candidate: ~$0.05 | Time saved: 15-20 minutes each
👥 Who's it for?
  • HR teams drowning in candidate applications
  • Recruitment agencies needing consistent evaluation criteria
  • Hiring managers seeking data-driven candidate insights
  • Companies looking to scale their team
  • Anyone tired of manual spreadsheet juggling
⚡ How it works
  1. Form submission triggers with CSV/XLSX upload
  2. Google Drive stores the file and creates a new Sheet
  3. Data extraction processes the file content
  4. AI Agent loops through each candidate:
    • Fetches up to 3 recent LinkedIn posts via Apify
    • Analyzes qualifications against job requirements
    • Generates evaluation score and Hebrew explanation
  5. Sheet formatting applies filters, sorting, and styling
  6. Error handling notifies admin of any issues
🛠️ Setup Instructions
Time to deploy: 15 minutes
Requirements:
  • Google account (Drive + Sheets access)
  • OpenAI API key (GPT-4.1 access)
  • Apify API key (for LinkedIn scraping)
  • Gmail account (for error notifications)
Step-by-step:
  1. Import this template into your n8n instance
  2. Configure Google credentials:
    • Connect Google Drive OAuth2
    • Connect Google Sheets OAuth2
  3. Add OpenAI API key to the GPT-4.1 node
  4. Set up Apify credentials for LinkedIn scraping
  5. Configure Gmail for error alerts (update email in "Send a message" node)
  6. Update folder IDs in Google Drive nodes to your folders
  7. Test with a sample CSV containing 2-3 candidates
  8. Activate and share the form URL with your team!
📋 Input File Format
Your CSV/XLSX should include these columns (Hebrew):
  • שם פרטי (First name)
  • שם משפחה (Last name)
  • חשבון לינקדאין (LinkedIn URL)
  • Your custom evaluation questions
🎨 Customization Options
Easy tweaks:
  • Scoring criteria: Modify the AI agent's system message
  • Language: Switch from Hebrew to any language
  • Scoring rubric: Adjust the 50/25/15/10 weighting
  • LinkedIn posts: Change from 3 posts to more/fewer
  • Sheet styling: Customize colors and formatting
Advanced modifications:
  • Add integration with your ATS (Greenhouse, Lever, etc.)
  • Connect to Slack for real-time notifications
  • Add multiple evaluation agents for different roles
  • Implement multi-language support
  • Add candidate email automation
💡 Pro Tips
  • Better LinkedIn data: Ensure candidates provide complete LinkedIn URLs (not just usernames)
  • Consistent scoring: Run batches of similar roles together for normalized scoring
  • Cost optimization: Adjust Apify settings to fetch only essential data
  • Scale smartly: Process in batches of min 10-20 for optimal performance
⚠️ Important Notes
  • LinkedIn scraping respects Apify's rate limits
  • Scores are relative within each batch - don't compare across different job roles
  • The workflow handles both CSV and XLSX formats automatically
  • Error notifications help you catch issues before they cascade
📊 Expected Results
After implementation, expect:
  • Data-driven evaluation across candidates
  • Professional explanation for hiring decisions
  • Happy recruiters who can focus on human connection
Built with ❤️ by Elay Guez
