Domain-specific web content crawler with depth control & text extraction
Created by: Le Nguyen || leeseifer
Le Nguyen
Last update 22 days ago
This template implements a recursive web crawler inside n8n. Starting from a given URL, it crawls linked pages up to a maximum depth (default: 3), extracts text and links, and returns the collected content via webhook.
🚀 How It Works
  1. Webhook Trigger
    Accepts a JSON body with a url field.
    Example payload:
    { "url": "https://example.com" }
  2. Initialization
    • Sets crawl parameters: url, domain, maxDepth = 3, and depth = 0.
    • Initializes global static data (pending, visited, queued, pages).
  3. Recursive Crawling
    • Fetches each page (HTTP Request).
    • Extracts body text and links (HTML node).
    • Cleans and deduplicates links.
    • Filters out:
      • External domains (only same-site is followed)
      • Anchors (#), mailto/tel/javascript links
      • Non-HTML files (.pdf, .docx, .xlsx, .pptx)
  4. Depth Control & Queue
    • Tracks visited URLs
    • Stops at maxDepth to prevent infinite loops
    • Uses SplitInBatches to loop the queue
  5. Data Collection
    • Saves each crawled page (url, depth, content) into pages[]
    • When pending = 0, combines results
  6. Output
    • Responds via the Webhook node with:
      • combinedContent (all pages concatenated)
      • pages[] (array of individual results)
    • Large results are chunked when exceeding ~12,000 characters
🛠️ Setup Instructions
  1. Import Template
    Load from n8n Community Templates.
  2. Configure Webhook
    • Open the Webhook node
    • Copy the Test URL (development) or Production URL (after deploy)
    • You’ll POST crawl requests to this endpoint
  3. Run a Test
    Send a POST with JSON:
    curl -X POST https://<your-n8n>/webhook/<id>
    -H "Content-Type: application/json"
    -d '{"url": "https://example.com"}'
  4. View Response
    The crawler returns a JSON object containing combinedContent and pages[].
⚙️ Configuration
  • maxDepth
    Default: 3. Adjust in the Init Crawl Params (Set) node.
  • Timeouts
    HTTP Request node timeout is 5 seconds per request; increase if needed.
  • Filtering Rules
    • Only same-domain links are followed (apex and www treated as same-site)
    • Skips anchors, mailto:, tel:, javascript:
    • Skips document links (.pdf, .docx, .xlsx, .pptx)
    • You can tweak the regex and logic in Queue & Dedup Links (Code) node
📌 Limitations
  • No JavaScript rendering (static HTML only)
  • No authentication/cookies/session handling
  • Large sites can be slow or hit timeouts; chunking mitigates response size
✅ Example Use Cases
  • Extract text across your site for AI ingestion / embeddings
  • SEO/content audit and internal link checks
  • Build a lightweight page corpus for downstream processing in n8n
⏱️ Estimated Setup Time
~10 minutes (import → set webhook → test request)
