Beginner's Guide to Workflow Automation with OpenAI, LangChain & API Integrations
Created by: Meelioo || mookielian
Meelioo
Last update 23 days ago
This beginner-friendly workflow demonstrates the core building blocks of n8n. It guides you through:
  • Triggers – Start workflows manually, on a schedule, via webhooks, or through chat.
  • Data processing – Use Set and Code nodes to create, transform, and enrich data.
  • Logic and branching – Apply conditions with IF nodes and merge different branches back together.
  • API integrations – Fetch external data (e.g., users from an API), split arrays into individual items, and extract useful fields.
  • AI-powered steps – Connect to OpenAI for generating fun facts or build interactive assistants with chat triggers, memory, and tools.
  • Responses – Return structured results via webhooks or summary nodes.
By the end, it demonstrates a full flow: creating data → transforming it → making decisions → calling APIs → using AI → responding with outputs.
Set up steps
Time required: 5–10 minutes.
  • What you need:
    • An n8n instance (cloud or self-hosted).
    • Optional: API credentials (e.g., OpenAI) if you want to test AI features.
  • Setup flow:
    • Import this workflow.
    • Add your API keys where needed (OpenAI, etc.).
    • Trigger the workflow manually or test with webhooks.
👉 Detailed node explanations and examples are already included as sticky notes inside the workflow itself, so you can learn step by step as you explore.
