Course recommendation system for surveys with data tables and GPT-4.1-Mini
Created by: Robert Breen || rbreen
Robert Breen
Last update 14 days ago
Use the n8n Data Tables feature to store, retrieve, and analyze survey results — then let OpenAI automatically recommend the most relevant course for each respondent.
🧠 What this workflow does
This workflow demonstrates how to use n8n’s built-in Data Tables to create an internal recommendation system powered by AI.
It:
  • Collects survey responses through a Form Trigger
  • Saves responses to a Data Table called Survey Responses
  • Fetches a list of available courses from another Data Table called Courses
  • Passes both Data Tables into an OpenAI Chat Agent, which selects the most relevant course
  • Returns a structured recommendation with:
    • course: the course title
    • reasoning: why it was selected
Trigger: Form submission (manual or public link)
👥 Who it’s for
Perfect for educators, training managers, or anyone wanting to use n8n Data Tables as a lightweight internal database — ideal for AI-driven recommendations, onboarding workflows, or content personalization.
⚙️ How to set it up
1️⃣ Create your n8n Data Tables
This workflow uses two Data Tables — both created directly inside n8n.
🧾 Table 1: Survey Responses
Columns:
  • Name
  • Q1 — Where did you learn about n8n?
  • Q2 — What is your experience with n8n?
  • Q3 — What kind of automations do you need help with?
To create:
  1. Add a Data Table node to your workflow.
  2. From the list, click “Create New Data Table.”
  3. Name it Survey Responses and add the columns above.
📚 Table 2: Courses
Columns:
  • Course
  • Description
To create:
  1. Add another Data Table node.
  2. Click “Create New Data Table.”
  3. Name it Courses and create the columns above.
  4. Copy course data from this Google Sheet:
    👉 https://docs.google.com/spreadsheets/d/1Y0Q0CnqN0w47c5nCpbA1O3sn0mQaKXPhql2Bc1UeiFY/edit?usp=sharing
This Courses Data Table is where you’ll store all available learning paths or programs for the AI to compare against survey inputs.
2️⃣ Connect OpenAI
  1. Go to OpenAI Platform
  2. Create an API key
  3. In n8n, open Credentials → OpenAI API and paste your key
  4. The workflow uses the gpt-4.1-mini model via the LangChain integration
🧩 Key Nodes Used
Node Purpose n8n Feature
Form Trigger Collect survey responses Forms
Data Table (Upsert) Stores results in Survey Responses Data Tables
Data Table (Get) Retrieves Courses Data Tables
Aggregate + Set Combines and formats table data Core nodes
OpenAI Chat Model (LangChain Agent) Analyzes responses and courses AI
Structured Output Parser Returns structured JSON output LangChain
💡 Tips for customization
  • Add more Data Table columns (e.g., email, department, experience years)
  • Use another Data Table to store AI recommendations or performance results
  • Modify the Agent system message to customize how AI chooses courses
  • Send recommendations via Email, Slack, or Google Sheets
🧾 Why Data Tables?
This workflow shows how n8n’s Data Tables can act as your internal database:
  • Create and manage tables directly inside n8n
  • No external integrations needed
  • Store structured data for AI prompts
  • Share tables across multiple workflows
All user data and course content are stored securely and natively in n8n Cloud or Self-Hosted environments.
📬 Contact
Need help customizing this (e.g., expanding Data Tables, connecting multiple surveys, or automating follow-ups)?
