Monitor RSS feeds, extract full articles with Jina AI, and save to Supabase
Created by: automedia || automate-social-media
automedia
Last update a month ago
Monitor RSS Feeds, Extract Full Articles, and Save to Supabase
Overview
This workflow solves a common problem with RSS feeds: they often only provide a short summary or snippet of the full article. This template automatically monitors a list of your favorite blog RSS feeds, filters for new content, visits the article page to extract the entire blog post, and then saves the structured data into a Supabase database.
It's designed for content creators, marketers, researchers, and anyone who needs to build a personal knowledge base, conduct competitive analysis, or power a content aggregation system without manual copy-pasting.
Use Cases
  • Content Curation: Automatically gather full-text articles for a newsletter or social media content.
  • Personal Knowledge Base: Create a searchable archive of articles from experts in your field.
  • Competitive Analysis: Track what competitors are publishing without visiting their blogs every day.
  • AI Model Training: Collect a clean, structured dataset of full-text articles to fine-tune an AI model.
How It Works
  1. Scheduled Trigger: The workflow runs automatically on a set schedule (default is once per day).
  2. Fetch RSS Feeds: It takes a list of RSS feed URLs you provide in the "blogs to track" node.
  3. Filter for New Posts: It checks the publication date of each article and only continues if the article is newer than a specified age (e.g., published within the last 60 days).
  4. Extract Full Content: For each new article, the workflow uses the Jina AI Reader URL (https://r.jina.ai/) to scrape the full, clean text from the blog post's webpage. This is a free and powerful way to get past the RSS snippet limit.
  5. Save to Supabase: Finally, it organizes the extracted data and saves it to your chosen Supabase table. The following data is saved by default:
    • title
    • source_url (the link to the original article)
    • content_snippet (the full extracted article text)
    • published_date
    • creator (the author)
    • status (a static value you can set, e.g., "new")
    • content_type (a static value you can set, e.g., "blog")
Setup Instructions
You can get this template running in about 10-15 minutes.
  1. Set Up Your RSS Feed List:
    • Navigate to the "blogs to track" Set node.
    • In the source_identifier field, replace the example URLs with the RSS feed URLs for the blogs you want to monitor. You can add as many as you like.
    • Tip: The best way to find a site's RSS feed is to use a tool like Perplexity or a web-browsing enabled LLM.
    // Example list of RSS feeds
    ['https://blog.n8n.io/rss', 'https://zapier.com/blog/feeds/latest/']
  2. Configure the Content Age Filter:
    • Go to the "max_content_age_days" Set node.
    • Change the value from the default 60 to your desired timeframe (e.g., 7 to only get articles from the last week).
  3. Connect Your Storage Destination:
    • The template uses the "Save Blog Data to Database" Supabase node.
    • First, ensure you have a table in your Supabase project with columns to match the data (e.g., title, source_url, content_snippet, published_date, creator, etc.).
    • In the n8n node, create new credentials using your Supabase Project URL and Service Role Key.
    • Select your table from the list and map the data fields from the workflow to your table columns.
    • Want to use something else? You can easily replace the Supabase node with a Google Sheets, Airtable, or the built-in n8n Table node. Just drag the final connection to your new node and configure the field mapping.
  4. Set Your Schedule:
    • Click on the first node, "Schedule Trigger".
    • Adjust the trigger interval to your needs. The default is every day at noon.
  5. Activate Workflow:
    • Click the "Save" button, then toggle the workflow to Active. You're all set!
