Retweet cleanup with scheduling for X/Twitter
Created by: masaya kawabe || kawabe03
masaya kawabe
Last update a month ago
Categories
Who’s it for
Social media managers, creators, and brand accounts that rely on retweets for reach but want an automated, hands-off cleanup after campaigns to keep profiles tidy and on-brand.
What it does / How it works
On a schedule, the workflow resolves your handle to a user ID, fetches recent tweets, filters retweets only, and safely unretweets them using batching and delays to respect rate limits. A dedicated CONFIG (Set Fields) node centralizes variables (e.g., target_username, max_results, batch_delay_minutes) so you can adjust behavior without touching logic.
API endpoints used
  • GET /2/users/by/username/{username} – resolve handle → user ID
  • GET /2/users/{id}/tweets?tweet.fields=created_at,referenced_tweets – fetch recent tweets (identify retweets via referenced_tweets.type === "retweeted")
  • DELETE /2/users/{id}/retweets/{tweet_id} – unretweet
Example response payloads
  "data": { "id": "2244994945", "name": "Twitter Dev", "username": "TwitterDev" }
GET /2/users/{id}/tweets (truncated)
  "data": [
      "id": "1760000000000000000",
      "text": "RT @someone: …",
      "referenced_tweets": [{ "type": "retweeted", "id": "1759999999999999999" }],
      "created_at": "2025-01-15T09:10:11.000Z"
  "meta": { "result_count": 20 }
{ "data": { "retweeted": false } }
Use cases
  • Brand hygiene: Auto-unretweet promos after 48–72h.
  • Campaign cadence: Remove event retweets once the event ends.
  • Feed freshness: Clear low-priority retweets on a rolling basis.
How to set up
  1. Open CONFIG (Set Fields) and replace placeholders:
    • target_username = "your_handle"
    • max_results = 100 (per fetch)
    • batch_delay_minutes = 2 (throttle between batches)
  2. Connect X/Twitter credentials in n8n (no keys hard-coded in HTTP nodes).
  3. Run once with small values, verify logs, then enable the schedule.
Optional enhancements: add a dead-letter path (Error Trigger → Set → Sheets/Email/Slack) and a notification node (e.g., Slack) for execution feedback.
