Recover missed demos with Calendly, Zoom & AI-generated follow-ups
Created by: Connor Provines || connorprovines
Connor Provines
Last update 22 days ago
One-Line Description
Automatically detects missed Zoom demos booked via Calendly and triggers AI-powered follow-up sequences.
Detailed Description
What it does:
When a prospect books a demo through Calendly but fails to join the Zoom meeting, this workflow automatically detects the no-show, generates personalized recovery messages using AI, updates your database, and notifies your sales team—all within minutes of the meeting ending. It bridges Calendly, Zoom, and your follow-up channels to ensure no lead falls through the cracks.
Who it's for:
  • Sales teams running high-volume demo calendars who lose 20-40% of booked meetings to no-shows
  • Customer success managers conducting onboarding calls where attendance tracking matters
  • SDRs and BDRs who need immediate alerts when prospects miss scheduled meetings
  • Revenue operations teams seeking to improve demo-to-opportunity conversion rates through faster follow-up
Key Features:
  • Real-time no-show detection - Automatically checks Zoom participant lists against expected attendees within seconds of meeting end
  • AI-generated recovery messaging - Creates contextual, empathetic follow-up emails and LinkedIn messages tailored to each no-show scenario
  • Instant team notifications - Sends formatted Slack alerts with attendee details and suggested next actions so reps can manually follow up if needed
  • Attendance tracking database - Maintains a searchable record of all bookings and attendance status for reporting and analysis
  • Multi-channel follow-up orchestration - Coordinates email, Slack notifications, and optional CRM updates from a single automation
  • Selective event filtering - Processes only specific Calendly event types so you control which meetings trigger the workflow
How it works:
  1. Booking capture: Calendly webhook fires when a demo is scheduled, extracting Zoom meeting details and attendee information
  2. Meeting monitoring: When the Zoom meeting ends, a second webhook triggers attendance verification by pulling the participant list from Zoom's API
  3. No-show identification: Workflow cross-references the expected attendee email with actual Zoom participants to confirm whether they attended
  4. Automated response: For confirmed no-shows, AI generates personalized recovery messages while the system updates your database and notifies your team via Slack
  5. Optional integrations: Simultaneously updates CRM deal stages or triggers additional follow-up sequences based on your configuration
Setup Requirements
Prerequisites:
  • Calendly account (any paid plan) with webhook access and Personal Access Token
  • Zoom account (Pro or higher) with Server-to-Server OAuth app credentials for API access
  • OpenAI API key for AI-generated follow-up message creation
  • Slack workspace with OAuth permissions to post messages (optional but recommended)
  • n8n Data Table created with columns: meeting_id, email, status (built-in n8n feature, no external database needed)
  • Email sending service configured in n8n (SMTP, Gmail, SendGrid, etc.) if enabling automated email sending
  • CRM API access (HubSpot, Salesforce, Pipedrive, etc.) if enabling deal updates (optional)
Note: Zoom API has rate limits (varies by plan); this workflow makes 1-2 API calls per meeting end event.
Estimated Setup Time:
45-60 minutes including Zoom app creation, Calendly webhook configuration, and Data Table setup
Installation Notes
Critical setup steps:
  • Zoom webhook validation: You must complete Zoom's webhook endpoint validation process before receiving real events. The workflow includes a dedicated validation path—run it once after creating your Zoom app.
  • Calendly webhook creation: Use the "Manual Setup Trigger" path in the workflow to programmatically create your Calendly webhook subscription. This only needs to run once.
  • Event type filtering: Replace the placeholder YOUR_CALENDLY_EVENT_TYPE_URI with your specific demo event type URI from Calendly to avoid processing all meeting types.
  • Test with a real meeting: Book a test demo, join briefly with a different email than the booking email, then leave. The workflow should detect the "no-show" for the booking email.
Common pitfalls to avoid:
  • Forgetting to enable the disabled "Send Recovery Email" node after testing (it's disabled by default to prevent accidental sends during setup)
  • Not configuring Zoom Server-to-Server OAuth correctly (requires Account ID, Client ID, and Client Secret—not JWT credentials)
  • Using a personal Calendly account instead of an organization account (webhooks require organization-level access)
  • Overlooking the Data Table creation step—the workflow will fail without this internal database
Testing recommendations:
  • Start with Slack notifications only (leave email sending disabled) to verify the workflow logic
  • Use your own email as a test booking to safely generate AI messages without sending to real prospects
  • Check the Data Table after each test to confirm booking records are being created and updated correctly
Customization Options
Easy modifications:
  • Swap email for SMS: Replace the email node with Twilio SMS to send text message follow-ups instead
  • Add delays: Insert "Wait" nodes to schedule follow-ups hours or days later rather than immediately
  • Change AI tone: Modify the OpenAI prompt to match your brand voice (casual, formal, humorous, etc.)
  • Multi-step sequences: Duplicate the AI and email nodes to create a 3-touch follow-up cadence over several days
  • Different CRM platforms: The HubSpot node can be swapped for Salesforce, Pipedrive, or any CRM n8n supports
Extension possibilities:
  • Add Google Sheets logging for executive dashboard reporting on no-show rates
  • Integrate with Calendly's rescheduling API to automatically send rebooking links
  • Connect to Loom or Vidyard APIs to attach pre-recorded demo videos in follow-up emails
  • Create a "second chance" discount workflow that offers incentives for rescheduling
  • Build a predictive model by exporting no-show data to analyze patterns (time of day, lead source, etc.)
Category
Sales
Tags
  • calendly
  • zoom
  • no-show-recovery
  • demo-automation
  • lead-follow-up
  • sales-automation
  • meeting-tracking
  • ai-messaging
  • slack-notification
  • openai
Use Case Examples
  • SaaS sales team: A B2B software company runs 40+ demos per week. When prospects no-show, this workflow immediately notifies the assigned rep in Slack with a pre-written LinkedIn message, sends an empathetic recovery email offering a Loom recording alternative, and flags the deal in HubSpot for manual outreach within 2 hours.
  • Agency onboarding: A marketing agency conducts discovery calls with new clients. If a client misses their scheduled kickoff meeting, the workflow logs the no-show, updates the client status in their CRM, and sends a friendly rescheduling email with three alternative time slots—all before the account manager even notices.
  • Customer success: A customer onboarding team tracks training session attendance. When users don't join their scheduled implementation calls, the workflow automatically sends a resource-rich email with documentation links, notifies the CSM team channel, and schedules a follow-up task in their project management tool.
