Auto-retry engine: error recovery workflow
Created by: Francis Njenga || gatura
Francis Njenga
Last update 10 months ago
Categories
Workflow Documentation: Auto-Retry Engine – Error Recovery Workflow
Detailed Description
The Auto-Retry Engine: Error Recovery Workflow is designed to automate the process of identifying and retrying failed executions in n8n workflows. By leveraging scheduled triggers, API integrations, and conditional logic, this workflow ensures that any failed executions are automatically retried on an hourly basis. This reduces manual intervention, improves system reliability, and ensures smoother workflow operations.
Who is this for?
This workflow is ideal for:
  • Automation Engineers: Managing and maintaining workflows with minimal manual intervention.
  • DevOps Teams: Ensuring high availability and reliability of automated processes.
  • IT Administrators: Reducing downtime and improving system performance by automating error recovery.
What problem does this workflow solve?
  • Manual Error Handling: Eliminates the need for manual monitoring and retrying of failed executions.
  • Improved Reliability: Automatically retries failed executions, reducing downtime and improving workflow success rates.
  • Time Efficiency: Saves time by automating repetitive error recovery tasks, allowing teams to focus on higher-priority work.
What this workflow does
This workflow automates the following steps:
  1. Scheduled Monitoring: Checks for failed executions hourly using a schedule trigger.
  2. Error Filtering: Identifies executions that have failed and filters out those that have already been successfully retried.
  3. Authentication: Logs into the n8n instance using API credentials to retrieve session details.
  4. Automatic Retry: Retries the failed executions using the n8n API.
  5. Batch Processing: Processes multiple failed executions in batches to avoid overloading the system.
Prerequisites
To use this workflow, you’ll need:
  • n8n Account: To create and run the workflow.
  • n8n API Credentials: For logging into the n8n instance and retrying executions.
  • HTTP Request Node: Configured to interact with the n8n API.
  • Schedule Trigger: Set to run the workflow hourly.
Setup Process
  1. Configure Schedule Trigger
    • Set the trigger to run hourly to check for failed executions.
  2. Set Login Credentials
    • Add your n8n instance URL, username, and password in the Set Node.
  3. Integrate n8n API
    • Use the HTTP Request node to log into the n8n instance and retrieve session details.
  4. Retry Failed Executions
    • Configure the HTTP Request node to retry failed executions using the session details.
  5. Batch Processing
    • Use the Split in Batches node to process multiple failed executions in batches.
How to customize this workflow
Tailor the workflow to fit your specific needs:
  • Adjust Schedule Frequency
    • Modify the schedule trigger to run at different intervals (e.g., every 30 minutes).
  • Add Notifications
    • Integrate email or Slack notifications to alert teams about failed retries.
  • Refine Error Filtering
    • Customize the filtering logic to exclude specific types of failed executions.
  • Scale Batch Size
    • Adjust the batch size in the Split in Batches node to optimize performance.
Conclusion
The Auto-Retry Engine: Error Recovery Workflow is a powerful tool for automating error recovery in n8n workflows. By reducing manual intervention and ensuring failed executions are retried automatically, this workflow enhances system reliability and operational efficiency. Whether you're managing a few workflows or a complex automation ecosystem, this workflow ensures your processes run smoothly and consistently.
